ce dials conversion
Old Aug 31, 2003 | 07:53 PM
Dressedinred's Avatar
ce dials conversion
Does any one know how to convert the ce dials from non-tach to tacho? Went to a couple of auto-elec but got blanck faces. Help please. I have already got the cluster and its just the rev counter that don't work
Cheers
Old Aug 31, 2003 | 10:02 PM
Mivec's Avatar
Mate not that hard, rexhunta has outlined the process for the CC dials. It is very simmilar for the CE. There is a tacho output under the bonnet against the firewall, if you are looking at the engine front the front of the car, it is on the left hand side on the firewall. It is not too hard to find. Hope that helps.
Old Sep 1, 2003 | 05:20 AM
On the back of the tacho I have there is different lables. Im guessing the 'tacho earth' goes to negitive of battery. The only other one that I can see is one called 'pulse' for the output on the fire wall. Would this be correct? Thanks for your help
Old Sep 2, 2003 | 07:28 PM
I so can not find that tacho output on the firewall, whats it near? Now i know why i dislike doing electronic things
Old Sep 2, 2003 | 09:01 PM
rexhunta's Avatar
nah its not on the firewall, you have to get it from the coil itself, i think it does go to pulse.. have you gotta workshop manual ?
Old Sep 2, 2003 | 10:32 PM
Mivec's Avatar
Actually it is Rexhunta it is on the right hand side on the firewall behind the air box/AFM area. It is a little plug which is the positive and well the negative just has to be ground. I though this would be a lot easier than actually hard wiring into the coil its self. As we say there is always a few ways to tackle a situation.
Old Sep 2, 2003 | 10:51 PM
rexhunta's Avatar
hrmm, i dont have that thing ! ill have a look tonight.. if i do, ill use it..unless its hiding, and i havent found it which my guess would be yes !
Old Sep 2, 2003 | 10:59 PM
Mivec's Avatar
I was just thinking it might only be on CE models which Dressedinred was after info on. Actually if you could have a look for me Rexhunta under the CC hood I would appreciate it. Then it will be time to attack my brother in laws car (he has a CC and wants to do the same conversion).
Old Sep 3, 2003 | 05:54 AM
rexhunta's Avatar
nah, the only way i could find, was the same way i did it in that other post..
Old Sep 3, 2003 | 02:17 PM
AJS85's Avatar
Wire for the revs
On the mivec wiring loom there's a plug that i came off for my shift light (since when i did the conversion the tacho worked without using the mivec dash loom so i didn't need to wire it up) the plug is right against the firewall near the brake boster.
Old Sep 3, 2003 | 10:16 PM
Yes i have just bought a manual today, which part of the book will have the location of this little plug?
Old Sep 3, 2003 | 11:00 PM
rexhunta's Avatar
probably under wiring ? no offense, thats where i found mine, under the wiring diagram, start at the main piece ( mine was the coil form the dizzie) and trace back
Old Sep 4, 2003 | 05:15 AM
Mivec's Avatar
Page 33
Old Sep 4, 2003 | 05:30 PM
Thanks guys, that helps heaps. Will try to hook it up pretty soon.
Old Sep 4, 2003 | 05:50 PM
Mivec's Avatar
Just for my benefit was it on the page I said? I thought last night ahh what if he has a different book (lol). Let us know how you go mate.
