MMC Lancer GSR turbo Upgrade
Old Sep 3, 2003 | 05:49 AM
Oscar's Avatar
Hi people,
I was thinking to perform a turbo upgrade to a TD05 for my Mitsubishi Lancer GSR 97´. I was looking hard for that turbo in my country but there were no good news.
Do you know somebody downthere selling that turbo? 2nd hand? new one? which one should i fit to my Lancer a 13G?, 15G?, 16G?
What extra-jobs sould i done to the engine or intake, exhaust system to get that turbo working properly?
By the other hand, a Mitsubishi Montero (Pajero) TD04 turbo is the same when comparing with the Lancer GSR series?
regards,
Oscar.
Old Sep 3, 2003 | 05:58 AM
rexhunta's Avatar
Yep, TD04 from a pajero, im pretty sure is the same turbo as the GSR and WRX..
Ive heard through the grapevine ( how much longer will you be mine ?) umm, the td05 will bolt upto your exhaust housing ? can anyone help me out on that ?
Old Sep 3, 2003 | 06:18 AM
Oscar's Avatar
I did not know that the Mits TD04 turbo were fitted in the WRX series....
My TD04 turbo is dying thats why im looking for a good replacement + Upgrade.
How much could a boost gauge cost in Australia? im looking for one to fit in my car...do you know somethig who had fit an EVO intercooler in a GSR? What is the main concern when you fit a bigger intercooler in your car? pressure - boost drop?
Well i hope people could answer your questions...
Thank you for the extremely quick response
Old Sep 3, 2003 | 04:10 PM
rexhunta's Avatar
Yes, the evo front mounts fit on the GSR's, but the one i looked at, he made up brackets.. simple once you take off the front bar..
Boost gauges are everywhere, specially at SuperCheap, where you can get the basic ones for 45 bucks (we got one last week for a project.. you'll hear bout it later ) then going all the way upto the apexi' and hks stuff.. bigger dollars..
Pressure drop shouldnt really be a hassle, as that is one of the performance upgrades for a GSR, as the lil pissy one just doesnt cut it for regular owners who up the boost a lil..
Old Sep 4, 2003 | 05:56 AM
Mivec's Avatar
Yes the TD05 will bolt straight up, I have heard that the tD04 off the rx will not fit, even though it is basicially the same as the GSR TD04 apparently it is alittle different.
Old Sep 4, 2003 | 06:31 AM
Oscar's Avatar
I just compared the EVO VII TD05-16G turbo (exhaust manifold couppled with the turbine housing) with my TD04 exhaust coupling and it was a completly different matter...first of all the EVO VII turbo´s flange (Turbine housing) has four studs as well as mine but located in a very different shape. In my car, the exhaust manifold flange is mounted in a level position but the EVO VII one is slightly inclined (if not then that TD05 could not fit properly).
Im not sure if former TD05 turbo exhaust manifold (EVO V, VI) are very similar with my Lancer GSR series but defintly the EVO VII is not.
Old Sep 4, 2003 | 04:35 PM
rexhunta's Avatar
Yeah, i would try a different TD05, maybe from an earlier evo, or check out the VR4 turbo..
You will find one, one day ! if not, mig and angle grinder, create your own
Old Sep 4, 2003 | 05:54 PM
Mivec's Avatar
Exactly, try Evo I, II or III or the VR4, as I am sure these fit. The CC series is totially different to the CE/CG.
Old Sep 4, 2003 | 06:03 PM
rexhunta's Avatar
*hint* i know wheres theres a VR4 Td05 sitting.. but you have to buy the complete engine and all
Old Sep 4, 2003 | 06:13 PM
Mivec's Avatar
You know you want it Pete....that would give your car just a touch more power
Old Sep 4, 2003 | 06:27 PM
rexhunta's Avatar
and preolly make the chassi twist and shudder and my axles die hehe
Old Sep 17, 2003 | 06:34 AM
TurboHead's Avatar
If its a 97 GSR then its not a CC Lancer... it would be the CE shape like the Evo4.
If this is the case then I don't think the VR4, Evo 1,2,3 turbos would fit as they are designed to face the opposite direction as the engine and gearbox were rotated 180 deg for the CE shape. Your best bet would be to source a turbo (or at least examine the possibilities of fitting one) from an Evo 4,5 and maybe 6... I'm pretty sure the Evo7 turbo was redesigned quite a bit which your experience would indicate.
If thats no good then just get a GT28 turbo and either get a custom manifold made or an adapter plate.
Old Sep 18, 2003 | 06:07 AM
Mivec's Avatar
Ahh dont I feel like a fool now, maybe I should get some glasses, how the hell did I miss the 97 part. Yes the Evo 5/6 sould do the trick. Sorry I am just so used to CC GSR's and we dont have the CE GSR here which is unfortunate, so that stuffed up my responce.
Old Sep 18, 2003 | 07:45 AM
TurboHead's Avatar
Easy mistake to make.... must say though - I would love to meet the **** for brains who decided that the whole engine and gearbox assembly would be swapped around 180 deg and slap him UP SIDE DA HEAD!!!!
I'm sure there was a reason for it but I sure can't see what it was.
BPAuto
EvoX 'For Sale' Interior Styling
13
Nov 20, 2016 09:03 AM
Wayne tihi
AWD Lancer (2012 +)
Oct 3, 2016 01:19 AM
imbest123
Sep 4, 2010 10:05 PM
GgreyEVOIX
52
Jun 11, 2006 09:45 AM
Oscar
Jul 24, 2003 11:29 AM
