Engine knock (CC 4G15)
Old Oct 13, 2003 | 08:25 AM
eze's Avatar
eze
yer, gots me a bit of a knock in my engine, it's been doing it for a while but lately its gotten worse, even over 3000 revs it still does it. What could be the cause or what can I do to hopefully get rid of it? I was thinking carby overhaul, could the timing be out?
it's gotten worse since my dad decided to fill up my oil with the same **** he uses in his vans (which are like less than 2 years old), a little too synthetic me thinks.
Old Oct 13, 2003 | 04:48 PM
AJS85's Avatar
Knock
I had a sound in the engine when accelerating like a knocking sound it came good after I did a service (New oil, spark plugs, oil and air filters) to my CC 4g15. But now I have the 4G92 Mivec in my CC no more knocking but I do have a second gear synchro problem now.
Old Oct 13, 2003 | 10:44 PM
eze's Avatar
eze
yeah I guess it came around the same time as after I had my 100k major service done. I too am now having problems with 2nd gear synchro (I know why though lol)
can't really afford an engine swap now or any time in the forseeable future :/
Old Oct 13, 2003 | 10:53 PM
AJS85's Avatar
Yeah instead of fixing my 2nd gear synchro i'm just going to buy a whole new mivec gear box haha so i don't car about when it grinds
Old Oct 20, 2003 | 05:11 AM
rexhunta's Avatar
Adjust the timing to 2 degrees, and run premium.. it may cost a lil more, but trust me on this, no pinging, and no pre-ignites when you turn your car off.. a big problem for me sometimes..
Old Oct 20, 2003 | 06:41 PM
eze's Avatar
eze
rexhunta: my car has occasionally dieseled (kept running a bit) after i turned it off, hasnt really bothered me. When I had my car serviced, at least one of the mechanics who worked on it was a ********, the sump plug was loose, and the oil filter tightened too much.
would not suprise me one bit if he ****ed up putting a new timing belt on as well. I'm gonna get the timing checked out.
Old Oct 20, 2003 | 06:53 PM
rexhunta's Avatar
I rang mitsi, cause i took it to a *reputable* repairer, and it was pinging like ****, and kept pre ingnitting, and he did **** bout it, got it back and was still doing it..so i took it to a friend who is a mechanic, and told him to do this this and this, and its fixed.
Old Oct 21, 2003 | 04:05 AM
eze's Avatar
eze
would an engine knock be caused the oil being too synthetic? The pinging has pretty much gone away as I drive more (and the oil thickens with k's doesn't it?)
I dont really wanna have to run premium because I get fuel on my parents shell card (ohh how sweet it is), and if they see premium on the account I don't think it would go down well.
Old Oct 22, 2003 | 12:26 AM
rexhunta's Avatar
Im not sure about the engine knock, i guess try it..
Yeah, i said im using Premium only to work from now on, and i can book it the joys of life sometime lol..
The bit of the engine igniting used to scare me sometimes, if you left it in gear when you turned it off, i've had it starting back up cause its pushed.. scary ****..
Pete
Old Oct 24, 2003 | 05:32 PM
Leppy's Avatar
Anyone know how to get the car to stop running after its turned off?? I have heards its real bad for the engine... I find that mine doesn't keep going if I run on premium but when on unleaded the little carby bastard won't stop running haha... Anyone know how to fix this??
Old Oct 24, 2003 | 10:10 PM
rexhunta's Avatar
Yep, thats what i had, and what i did fixed it.. 2 degrees and premium is the only way..
Old Oct 24, 2003 | 10:19 PM
eldanoloco's Avatar
Is it knock or rod-knock, it came off to me as you heard it not datalogged it. The diesleing could be timing or carbon tracks. But if its rod knock, better go easy on it till you got the cash for a new engine.
Old Oct 25, 2003 | 04:10 PM
Leppy's Avatar
What is rod knock?? and is it terminal?
Ian0611
16
Sep 27, 2023 01:42 PM
Kreeker
Sep 13, 2016 11:17 AM
Bugermass
70
Apr 30, 2010 11:02 PM
smokedmustang
103
May 11, 2006 08:19 AM
TrinaBabe
Oct 31, 2004 10:49 PM
