Automotosports - Illinois Automotosports is a Chicago based tuner specializing in 4G63T performance. With an in-house fabrication facility and engineers on staff, they will be bringing you the best in Lancer Evolution parts.
How fast is an EVO 8 with these mods:
Old Aug 3, 2005 | 11:52 PM
fre's Avatar
fre
on the stock ecu your looking at low 12s MAYBE high 11s if you can really drive. It is going to take at least 25psi to hit a mid 11 in my opinion. On stand alone (aem) I have no clue, because I don't have experience with them. That will soon be remedied in a week or so though
Old Aug 8, 2005 | 09:34 AM
Rollaway's Avatar
Originally Posted by Lancerlover
Is that with race gas?
pump gas
Old Aug 15, 2005 | 04:17 PM
Mooshu1221's Avatar
so how high of boost can u run with GT35R on pump gas without problems?
Old Aug 15, 2005 | 05:08 PM
Ludikraut's Avatar
91 Octane = ~21psi
93 Octane = ~23psi
94 Octane = ~24psi
Note the ~, which means approximately. Some cars can run those values w/out knock, some cannot. If you throw alky injection into the mix, then you can run significantly more boost. These figures apply to pretty much any turbo setup on the Evo ... the limiting factor is not the turbo, it's the octane rating (and the tuning )
l8r)
Old Aug 15, 2005 | 05:27 PM
evo_il8's Avatar
Stock turbo can handle 22 psi so stick with stock if youre only looking for boost in the low 20s.
22psi on a gt35 is definetly not the same as 22 psi on the stock turbo
Old Aug 15, 2005 | 05:48 PM
fre's Avatar
fre
Edited for simplicity.
How so? The bigger turbo produces boost easier so it will have cooler air output. This results in slightly more air than the stock turbo at reasonable boost levels (20 and below), but not enough for large gains.
Old Aug 15, 2005 | 06:39 PM
Knower's Avatar
Originally Posted by fre
How so? At 22psi the same amount of force is being applied to push the air into the engine, the bigger turbo just does it easier and can more easily hold it stable till redline. Trust me tune two cars with identical setups, one with a gt35r and one with a stock turbo and run 22psi in both and then see what they run at the track. I bet the times are almost identical. People keep saying well this turbo flows more air..... Yes it flows more air, but that just means it works less to maintain the same boost level.
The only reason people might see a difference between the two turbos running the same boost at the track is because the stock turbo can't sustain as high of boost as long as the bigger turbo can or the bigger turbo car has a lot more work done, which is usually the case.
What I am saying in short is in a given volume i.e. your intake track and manifold at any given constant pressure you have the same amount of air no matter what. The only way to increase the volume of air in a constant volume is to increase the pressure (density).
Every person who took 12th grade physics is laughing at you. Hell, 8th graders are probably laughing at you. Pressure is not density. All the evo tuner wannabes believing that airflow at 22psi on a stock turbo is the same as airflow at 22psi on a GT35R should go learn the basics of physics most of us learn in 8th grade.
Old Aug 15, 2005 | 06:43 PM
Phalse's Avatar
Fre, I gota say, I'm very suprized someone who would post things like that, has a car running an 11.5 @ 123. Someone else told you what to buy and tuned it for you, Id think?
Old Aug 15, 2005 | 07:20 PM
evo542's Avatar
you forgot temperature...., the GT-35R will definetly flow more air at the same pressure as the stocker
Old Aug 15, 2005 | 08:38 PM
fre's Avatar
fre
Old Aug 15, 2005 | 09:15 PM
fre's Avatar
fre
Old Aug 15, 2005 | 09:53 PM
tama_mog's Avatar
On behalf of other math and cs guys out there....please stop fre. Thanks.
Old Aug 15, 2005 | 10:44 PM
fre's Avatar
fre
Simplicity:
I have personal experience on this subject which is why I now convey what I wanted to say in the first place. Sorry I gave you a headache, but it's true. I will make it simple for you. Prove me wrong and I will say no more. Prove that a gt35r makes 50 more hp than a stock turbo at 19psi and I will shut up until then silence, thanks.
Old Aug 16, 2005 | 03:15 AM
Knower's Avatar
Simplicity:
It's obvious that your strength isn't debate either. Stop twisting things around. Nobody said that a GT35R makes 50 more hp than a stock turbo at ANY given psi. You are a true joke, acting like an expert and then throwing out a completely arbitrary requirement in order for others to "disprove" your halfass theory, along with editing out all your completely wrong statements for "simplicity."
To answer the thread starter's question, with all supporting mods to the mods you had listed, you should make ~400whp with an aggressive tune on 91 octane @ 22psi. Quarter mile times have already been answered by people more knowledgeable than I.
Old Aug 16, 2005 | 06:19 AM
fre's Avatar
fre
LOL well that was the point I was trying to convey in my first post I just got into too much detail and wasn't successful in conveying what I wanted to say (misuse of terms). It's not like I am the only one that has misused words on here. My only point was that CFM will be the same or very close to the same at any given pressure, it is just that the larger turbo can produce more overall CFM, making it easier to hold boost. Did I say that right? Oh please correct me if I am wrong But, but but you forgot temperature... ok, but it is such a small change at boost levels mentioned i.e. 22psi I didn't really think it was significant enough to mention. Was that an arbitrary argument? I was just trying to make it simple for those that couldn't understand what I was trying to say, so I explained it with power differences.
