How fast is an EVO 8 with these mods:
Peak HP won't be dramatically different on pump gas (what, maybe 15-30whp?). However the torque curve will be significantly different, with a bigger turbo (aka gt35r) making all of its power in the upper rpm range and a smaller turbo (aka stock) making most of its power in the middle rpm ranges.
Now when you're talking 1/4 mile times you also have to consider gearing and spool. Stock Evo gearing will have you between redline and ~5400 rpm for most of your run, which would favor the bigger turbo, since it is generating its power in the upper rpm range. However the slower spool negates that advantage everytime you shift, so unless you can shift w/out lifting your foot off the gas (read: keep turbo spooled to some degree), your 1/4 mile times will be very close. With no lift shifting the gt35r should be quicker.
l8r)
l8r)
l8r)
l8r)
Originally Posted by Knower
It's obvious that your strength isn't debate either. Stop twisting things around. Nobody said that a GT35R makes 50 more hp than a stock turbo at ANY given psi. You are a true joke, acting like an expert and then throwing out a completely arbitrary requirement in order for others to "disprove" your halfass theory, along with editing out all your completely wrong statements for "simplicity."
To answer the thread starter's question, with all supporting mods to the mods you had listed, you should make ~400whp with an aggressive tune on 91 octane @ 22psi. Quarter mile times have already been answered by people more knowledgeable than I.
Knower have seen a couple gt35r cars played out here in southern california including mine. Using me as an example, I made 410whp on 91 octane on 21psi on a conservative tune, we've pushed it farther since then and got 425whp in 100 degree weather @ tuning technology.....Is 20-23 psi the most efficient way to use a gt35r? Certainly not, I've ran a racegas map making around 540whp on 30psi and it certainly makes the 91 map seem slow. But I would not go as far as to say it is unusable and I certainly would not expect a stock turbo to outrun the car @ 19-21psi, assuming both cars are setup right. So if you're speaking of "real-life" experiences with cars with gt35r. There are plenty of examples over here. Point is, 19psi on a stock turbo != 19psi on a bigger turbo. Which is what Fre was trying to substantiate earlier.
I agree, I am not here to internet dyno race anyone. But I am simply refuting your claim that 19psi on a stock turbo vs 19psi on a gt35r yields similar result. That with your earlier explanation of pressure vs volume does not add up. Have a good day.
l8r)
A stoker at 19psi will outrun a 35r @19psi. This is because the 35r is not in its efficient range yet. In fact , the stock turbo will put down a much broader range of torque and hp vs the 35r at 19psi. The 35r may put down a higher whp at 19psi but it would be at a higher rpm and for a short time, with much less torque.
If you guys are speaking of using the rpm ranges the stock turbo is good for, then yes I agree the gt35r does not outperform the stock turbo. But where it shines is in the upper rpms and if you're building a gt35r on a 2.0 liter to rev to 7800 rpms, then that indeed is defeating the purpose. But I'm assuming most wouldn't do somethin like that and would build the motor and head to rev to 9000ish+. And yes I agreed already dyno racing is lame and let's just get back on topic....the thing that bugged me the most was your original posts and that did not reflect your "point" that you are making now about stock vs gt35r.
And as to the comment about having dyno comparisons, I have many of those as well. Tuning Technology is a pretty popular place for socal people to tune their cars, so there are countless dyno graphs of the stock turbo done there. I don't see any stock turbo cars making remotely close to 400whp on 91 octane on the same boost.
the gt35r really shines when running a 2.3 stroker motor..my racegas tune is making 550whp on 110oct @ 25psi only and 440whp at 18psi on 94oct..raising the boost to the max level possible isnt always the best way to make power..run less boost more timing can make same hp numbers with lower boost
The figures are hardly inflated I assure you, this dynojet is very consistent in comparison with other dynojets out there. But I am not here to race whp on gay dynos (I will state once more). If you want to see my mods, here's an approx list:
https://www.evolutionm.net/forums/sh...d.php?t=152765
That's my thread on thinking of selling my car.
I agree with the statement about the timing issue. Boost obviously does not always equate to power, anyone with any knowledge of what's going on in tuning knows that. Unfortunately, it is hard for me to advance any kind of decent timing on 91 octane. My next power mod whenever my 2.0 motor dies is gonna be a 2.4 bottom end, that is without question. The gt35r + the 4g64 definitely makes for a better daily driver and better setup overall.
To put someone down because they may not have the exact and correct words to explain his point is simply CHILDISH. There are many people on EVOM that have a great way with words and making great sense, that is on paper and doesn't translate at all into the real world. So surprise or not , an editor for a magazine will not make a competent technician. SO go on if you please with put downs, all it means is that you have a way with words, thats it. FRE has experience, more so than many on here. He actually has a AMS kit on his car also. I dont disagree with his point, in fact I understand what he's trying to say. I run the AMS gt35r kit on alky/93 octane mix @25psi all day. There is in fact no use for the 35r on 22psi, its simply not usable . By the time you actually get to 22psi any stocker will be way ahead out of reach. Even at 25 psi that turbo is barely breathing. 11.5 1/4 mile @22psi is hard to beleive.
The statements FRE is making now are much more reasonable/realistic. This thread has gone fairly far off topic, so I digress.
