How fast is an EVO 8 with these mods:
*GT35 turbo
*22psi of boost
*Headers
*cams
*Exhaust
*CAI
*Stage III Clutch
*NO CATS
and all other supporting mods needed
How much AWHP (roughly) is expected with these mods and a rough 1/4 time? thanks
*22psi of boost
*Headers
*cams
*Exhaust
*CAI
*Stage III Clutch
*NO CATS
Originally Posted by Ev0ikon
Yeah.. up the boost. It should be good for low 11 to high 10sec.
*GT35 turbo
*22psi of boost - you'll be running more than that
*Headers - there's only 1 header
*cams - 272's
*Exhaust - full 3" turbo back
*CAI - not needed, just use an open-element
*Stage III Clutch - don't go by stage, just get a double or triple exedy
*NO CATS - there's only 1 cat, replace it with a test pipe
You'll be running low 11's
*cams - 272's
If your only going to run 22psi with a 35R you would be better off sticking with the stock turbo IMO and spend the money on a stand alone. You reliable see 375awhp out of the stocker with great torque to boot.
If I had to guess I would say 350awhp.
If you're going to limit yourself to pump-gas levels of boost, then you're probably going to see a mid to high 11 sec 1/4 mile and roughly 400whp (maybe a little more, but not much). Once you throw racegas or alky into the mix and turn up the boost, you'll see low 11's/high 10s (depending on how good you can drive)
l8r)
l8r)
Originally Posted by JaguarS4R
*GT35 turbo
*22psi of boost
*Headers
*cams
*Exhaust
*CAI
*Stage III Clutch
*NO CATS
*22psi of boost
*Headers
*cams
*Exhaust
*CAI
*Stage III Clutch
*NO CATS
i made 405whp on my old white evo with that setup on 21psi
A GT35R can handle boost upwards of 35psi or so, with race gas on stock block (not bored out) you'll be making around 540 whp. With pump gas, probably around 450 whp. This is with 35 pounds of boost. when you lower it to 22 psi (only 2 pounds more than stock) you wont be making much power off the bigger turbo but rather more off the cams, headers, exhausts ect. (all the naturally aspirated items which can only go so far). Stock turbo can handle 22 psi so stick with stock if youre only looking for boost in the low 20s. Its a waste of money for a bigger turbo when all the power is coming off of naturally aspirated items like i have listed above. You will probably get somewhere around 315-345 awhp with 22 psi setup on pump gas. But AMS GT35R kit is incredible for evos because of the power gains (35psi boost setup) and reliability.
Originally Posted by Lancerlover
...You will probably get somewhere around 315-345 awhp with 22 psi setup on pump gas...
l8r)
From: RAMAR village, pampanga PHILIPPINES, Temecula, CA
i have the gt35r and i am only running 22 psi's everyday due to cali **** gas....
want to bulletproof the engine and tranny before i up the boost to 35 psi's.
