Automotosports - Illinois Automotosports is a Chicago based tuner specializing in 4G63T performance. With an in-house fabrication facility and engineers on staff, they will be bringing you the best in Lancer Evolution parts.
Need help FAST.
Old Jul 24, 2005 | 08:44 AM
Nesiop's Avatar
Need help FAST.
K, am installing an AMS 35r turbo kit on an Evo, and realized the DP that came with the turbo kit is a 3 bolt flange on the o2 housing side which is normal cause it is a 3 bolt end, and also the car is running an Ultimate Racing Cat delete but that is a 2 bolt flange, as is the stock cat but the other end of the downpipe is a 3 bolt flange also. Why did AMS send that kind of pipe when even the stock cat is a 2 bolt flange? Did anyone else have this happen or know how I can fix it?
Old Jul 24, 2005 | 08:54 AM
Smogrunner's Avatar
Go to the nearest muffler shop, they'll match things up and have you on the road in an hour. 3 bolt is stronger than 2, right? Different shop's custom exhausts commonly don't just bolt up to some other shop's custom exhaust.
Old Jul 24, 2005 | 09:03 AM
Nesiop's Avatar
Well UR's is matched to the same pattern as the stock cat, it is just odd how ams's came as a 3 bolt when the ones they sell with there turbo backs are 2 bolts according to their pic.
Plus it is sunday, any of them open?
Old Jul 24, 2005 | 09:10 AM
Nesiop's Avatar
So did they make a mistake and flange it wrong?
Old Jul 24, 2005 | 09:12 AM
o3evo8's Avatar
Veteran: Air Force
you might have gotten a original design of AMS's downpipe which had a 3 bolt flange
Old Jul 24, 2005 | 09:30 AM
Smogrunner's Avatar
Mine is a three bolt too. So, not a mistake.
Old Jul 24, 2005 | 09:40 AM
Nesiop's Avatar
Both sides?
If so how did you bolt it to your cat or cat delete?
Old Jul 24, 2005 | 09:58 AM
Nesiop's Avatar
bump
Old Jul 24, 2005 | 10:22 AM
Nesiop's Avatar
Originally Posted by Nesiop
Both sides?
bump
Old Jul 24, 2005 | 10:36 AM
Smogrunner's Avatar
I haven't yet. Tuning Techologies will just grab a matching flange and weld it up...
Old Jul 24, 2005 | 10:46 AM
Nesiop's Avatar
So it has to be a mistake, it doesn't make sense why we should have to flange from a stock or aftermarket flange. Even there normal dps come 2 bolt
Old Jul 24, 2005 | 10:50 AM
rlazer5000's Avatar
Actually it's no mistake. AMS uses 3 bolt flanges on all their EVO exhausts. The only way to make it fit is to weld up a 2 bolt flange. I guess AMS uses the 3 bolt flange as it is stronger. It kind of sucks because everything else on the market has a 2 bolt flange, so nothing is compatible with anything AMS. I made the same mistake when I bought a high-flow cat from them. There should be muffler shops open, but the question is finding which one. Good luck man!
Old Jul 24, 2005 | 11:58 AM
Stop&TurnFreak's Avatar
It is much stronger, I had the bolts backing out when I was using the two bolt setup, but with the three bolt, I haven't even checked the bolts in 2 months, as they never move. When I was using the two bolts, I tried everything, double-nutting, lock nuts, you name it, but they kept backing out during my 20-30 minute runs on track.
Old Jul 24, 2005 | 12:00 PM
Nesiop's Avatar
So basically they force you to spend money to reflange or to buy there cat delete or hfc to make it work?
Old Jul 24, 2005 | 01:49 PM
AutoMotoSports's Avatar
we dont force you to do anything. Even our turbo back exhaust uses three bolt flanges. It is what we have been doing for three years. You get a more even seat with three bolt flanges. you will also notice our flanges are much much thicker then anyone else i Have see. we have them water jet cut that thick to prevent warping. All of our components are designed to stand the test of time. the downpipe in our turbo kit was designed to bolt up to our test pipe / cat and our catback. Beacuse most customers that have our turbo kit also have our catback exhaust.
Eric
