Automotosports - Illinois Automotosports is a Chicago based tuner specializing in 4G63T performance. With an in-house fabrication facility and engineers on staff, they will be bringing you the best in Lancer Evolution parts.
Boost taper
Old Feb 13, 2007 | 05:19 AM
Jeepboy's Avatar
Boost taper
With a custom flash for an EVO8 is it possible to have the ecu control boost and eliminate or reduce the amount of stock boost taper? If not, how much boost taper will there be?
I'd like to have increased boost and very little taper but I also like having the ecu adjust for atmospheric conditions.
Thanks
Old Feb 13, 2007 | 05:24 AM
boostinjuice's Avatar
get a mbc.. helps alot
Old Feb 13, 2007 | 10:29 AM
AutoMotoSports's Avatar
having the ECU controll the boost will help. The MBC will help better but there is no way to completely eliminate it.
Eric
Old Feb 13, 2007 | 12:00 PM
Jeepboy's Avatar
How much more effective is a MBC versus the ECU at eliminating boost taper? Is it just 1-2 psi or more like 5-6 psi?
Old Feb 13, 2007 | 12:19 PM
RoadSpike's Avatar
The problem is the ECU's boost control is a bleed type system which maxes out its capacity seemingly around the 20-21psi mark. There are ways to improve it but its easier to go with a manual boost controller at this point.
Old Feb 13, 2007 | 12:38 PM
Jeepboy's Avatar
How much boost does 93 octane support?
Old Feb 13, 2007 | 12:44 PM
RoadSpike's Avatar
Depends on how aggressive your ignition map is.
Basically just let the tuner set the boost points for you ok
Old Feb 13, 2007 | 12:51 PM
Jeepboy's Avatar
I'm trying to decide if I should get a MBC before getting tuned.
Old Feb 13, 2007 | 01:44 PM
EVOBrad's Avatar
Definitely. They're inexpensive, very effective, and easy to install.
Old Feb 13, 2007 | 02:38 PM
MBC is the better way to go
19fred82
Jun 14, 2011 06:39 PM
2005evo8gsr
Oct 16, 2010 02:41 PM
SyZyGy1394
14
Apr 26, 2010 12:45 AM
Varrius
Aug 24, 2006 06:04 PM
