Disabling CDN Lancer Daytime Running Lights
Old Apr 27, 2004 | 01:53 AM
felony's Avatar
I did this on both of my eclipse's the drl box was on the passenger side kick panel, you pull out a board and no more day time runners. Im guessing that there is the same type of thing in the new lancers, i too dislike day time runnres but be warned take your car in for a checkup and the dealer will lose it on your ***, and so will any ******** cop
Old Apr 27, 2004 | 10:38 AM
psy-q's Avatar
I'm only going to wire up a toggle switich. 95% of the time they will still be running.
Graeme was nice enough to fax me a copy of the wiring diagrams. Maybe today I'll get my digicam out and document how to do it. Then i'll make a new thread that the moderators can stick for all to see.
Old May 19, 2004 | 06:37 AM
sillypuddy's Avatar
anybody ever figure out this 'magic box' you have to pull??
-joe
Old May 19, 2004 | 11:25 AM
psy-q's Avatar
I can't find it in my car. The only place I haven't checked is behind the left front fender.
There is a connector that goes to this DRL ECU that would be super easy to pull/by-pass, but I can't find it. The diagrams I have are for an 03 Lancer, so its possible the 04 is built right into the main ECU. From what I've seen of 03s I don't think this is the case though. They all look the same.
Just waiting for a chance to go over to Mitsu and ask them.
Old May 19, 2004 | 12:30 PM
cih's Avatar
cih
For the canadian lancers .. i believe it is in the drivers side below the headlamp unit, the place where you would have the end of your Cold Air Intake.
snip the wires
Don't quote me on this.. but .. ya
Old May 19, 2004 | 12:34 PM
psy-q's Avatar
its not, trust me.
Old May 19, 2004 | 12:46 PM
cih's Avatar
cih
then what the hell was that little box there ?
Old May 19, 2004 | 12:48 PM
psy-q's Avatar
ok, i'll go look again. brb
Old May 19, 2004 | 12:52 PM
psy-q's Avatar
Don't see it. If you have pictures/electron micrographs please post them. We could us all the help we can get.
Old May 19, 2004 | 01:08 PM
cih's Avatar
cih
Ohhh wait.. mines an 2003
might be in a different spot
Old May 19, 2004 | 01:15 PM
jtc's Avatar
jtc
hmm. i have the lancer shop manual on cd, i'll see if it's on there when i get home.
it might be in under the valve cover, just give it a good hammer. oh wait, i drive a kia rio. never mind.
Old May 19, 2004 | 01:27 PM
Danno's Avatar
all i have to say to this thread is WHY! Why yould you want to disconnect a safty feature like that. Im tired of seeing people drive in the fog with no lights on at least this will partly help those tards out. I personally drive with my lights on all the time. Why? cause i want ouher cars to se me more. THere are two ways of looking at it:
If your lights are off and someone starts loosing control they wont focus on you and therefore have less chance of being in an accident.
or 2 - if your lights are on then people will see you easier and in turn will not pull out infront of you, cut you off or anything else (as often)
I figure that since every car isnt loosign control i play the odds and leave my lights on.
If your doing it for presintation purposes then simply turn your car off when its sitting at the local timmy's or whatever.
Old May 19, 2004 | 02:00 PM
psy-q's Avatar
Danno, this question has been left unanswered because so many people like yourself go off on another tangent. It’s a simple problem, the reasons for doing/not doing it are not required, nor are safety lectures.
jtc, I have the parts of the 03 Lancer shop manual here and have been going over them like crazy. The DRL ECU seems to have a 6-pin socket that acts like a bypass for the headlights. If it was unplugged the whole system would fail to work. I believe it was the white wire that could be spliced with a toggle switch to control them.
The 04 manual would be my holy grail
Edit:
Related thread on LancerNation. http://lancernation.net/viewtopic.php?t=18
Old May 19, 2004 | 08:29 PM
sillypuddy's Avatar
some of us DO drive with the lights on all the time
but sometimes we want to just have the markers lights on (at meets, etc) but we CAN'T
so we want to do this mod to fix that problem
so don't start with the safety lessons
-joe
Old May 19, 2004 | 08:33 PM
cih's Avatar
cih
marker lights, just flick your light switch one notch and don't have your engine running.
