Disabling CDN Lancer Daytime Running Lights
Old May 20, 2004 | 06:30 AM
  #31
Danno's Avatar
^ exactly
Old May 20, 2004 | 10:15 AM
  #32
psy-q's Avatar
I want the engine running. If i'm showing off my engine mods, etc. I don't want my headlights on. This is for show only. Simple right? Safety can kiss my
Old May 20, 2004 | 10:35 AM
  #33
Danno's Avatar
thats cool i understand that.
here is a tip for doing it.
Get a multi meter and turn your car on with your lights off (so the DRL is on). test to see which wire has power running to it.... splice into it and run a wire for your togle switch.
With the difficulties that it seems everyone is having that would be my best suggestion on doing it. Maybe i will try it tonight to see if it works, take pictures and post them (if i have time, or remember the pictures) as a how too.
FYI your will NOT be on left if you forget to turn the switch off (incase anyone is wonderingmost people would have figured that out though.)
Old May 20, 2004 | 11:38 AM
  #34
cih's Avatar
cih
EASIER SOLUTION :
unplug your bulbs at shows.
Old May 20, 2004 | 02:41 PM
  #35
psy-q's Avatar
Actually thats a good idea. Just toggle the power to the headlights completely. Of course I'd want to be sure there is no way to kill the DRLs beofre I start modding my headlights
<3am, psy-q's lights die due to tampering. Kaboom>
Old May 22, 2004 | 06:25 AM
  #36
sillypuddy's Avatar
cutting and splicing in a toggle switch is not easier..
the only difference between and US RA and a Canadian RA is that there is a little box (relay and some circuits) that plugs into certain spot.. unplug that and you have a US spec RA with no DRL.. when you bring it back to the dealer, just plug it back in and you are set
i want to see how you can explain the splice wire to the dealer.. it's a nasty and brute force way to solve our simple problem
-joe
Old May 22, 2004 | 10:42 AM
  #37
psy-q's Avatar
I want to be able to control it, not kill it. Splicing a wire will not be a problem as long as its to a toggle and not to power something.
Old May 22, 2004 | 05:10 PM
  #38
sillypuddy's Avatar
I just need to know where this box is.. then i can wire a toggle to that instead..
-joe
Old May 23, 2004 | 03:11 PM
  #39
psy-q's Avatar
If your adventurous you could check inside the left front fender. Only place I haven't looked yet
Old May 25, 2004 | 05:33 AM
  #40
Danno's Avatar
Originally Posted by cih
For the canadian lancers .. i believe it is in the drivers side below the headlamp unit, the place where you would have the end of your Cold Air Intake.
snip the wires
Don't quote me on this.. but .. ya
I thought that was an ABS sensor or something because i have it and gord doesn't (I think)
Old May 25, 2004 | 01:16 PM
  #41
cih's Avatar
cih
Ummmmm.. no comment.
Consult a mechanic at a different dealership than the one you usually go to.
Old May 31, 2004 | 07:32 AM
  #42
Danno's Avatar
okay i will stop whgoaring up all the threads now...i have all of page 1 and a lot of page 2
Old May 31, 2004 | 07:36 AM
  #43
sillypuddy's Avatar
danno.. you just ***** it up again
i asked the guy at the dealer to look up the part # for the "DRL ECU" so I can see the exploding diagram.. can't find it.. anybody know what else it's called?
-joe
Old May 31, 2004 | 11:24 AM
  #44
psy-q's Avatar
I should be able to find the part number on the lists I have. It's at home, PM me if I forget to post it later.
Old Jun 1, 2004 | 09:27 PM
  #45
enjoku's Avatar
Anyone found it yet for the Ralliart???
