Good Map for this setup?
Old Dec 18, 2011 | 04:33 PM
jdm_ed's Avatar
Guys does anybody have a good map for the following mods on a 08 EVO X MR:
- ETS Intercooler and piping kit
- Downpipe and Borla Cat Back
- AEM Cold Air Intake
- Stock BOV
Any help will be appreciated.
Old Dec 19, 2011 | 12:21 PM
Kracka's Avatar
Most likely "Stage 2+AEM". HFC/testpipe?
Old Dec 19, 2011 | 12:24 PM
T6's Avatar
T6
What he said.
Here is a link for the OTS maps:
http://cobbtuning.com/info/?id=5951
Old Dec 20, 2011 | 09:50 AM
jdm_ed's Avatar
Testpipe
Old Dec 26, 2011 | 03:16 PM
DocBoz's Avatar
yip
Old Dec 26, 2011 | 03:26 PM
johnnnyjeans's Avatar
correct
Old Jan 15, 2012 | 05:15 PM
jdm_ed's Avatar
OK so next question:
I'm currently running the Stage 2 AEM 93 oct (non-LWG) map. When monitoring boost with the AP I saw a spike up 26-27 psi. Does this mean I should be running the LWG map?
Old Jan 16, 2012 | 01:07 AM
mirkendargen's Avatar
I think 26-27PSI is the target boost for the 93 maps. Unless you have knock issues I think it's fine.
Old Jan 16, 2012 | 08:43 AM
jdm_ed's Avatar
OK but I just installed an AEM Wideband and when it spools it's reading lean 11-12. Cruising is stoich which I'm taking as the sensor reading correctly...
Where do I take it from here?
Old Jan 16, 2012 | 09:03 AM
Kracka's Avatar
Boost sounds fine. Where's AFR under WOT once the turbo is fully spooled? Any knock?
Evo_Goodness
Aug 30, 2016 04:00 AM
mikgsxx
Feb 23, 2016 10:07 AM
turboedv6
Aug 29, 2015 06:37 AM
dubs&boost
Feb 26, 2014 06:14 PM
BSREVOLUTION
11
Feb 28, 2005 04:29 PM
