Cobb Stage 2 Overboosting
Old Jun 2, 2012 | 10:45 PM
MivecAddict's Avatar
I just flashed to the stage 2 93 octane AEM intake map and while logging I noticed that I am overboosting to high 27 psi and experiencing boost cut in the higher rpm range. I removed the boost pill per Cobb's instructions and the only mods I have are the AEM intake and TurboXS TBE. Should I put the pill back in? If so can anyone tell me which way the smaller opening of the pill should be facing (towards the intake or away). I wasn't paying attention when I removed it.
Old Jun 3, 2012 | 01:57 PM
It also appears that my hose from the fuel pressure regulator to the intake manifold popped off and is causing fluctuating idle.
Old Jun 3, 2012 | 02:59 PM
Iowa999's Avatar
Wow. 27 psi and no pressure signal to the FPR ... be happy you still have an engine.
Oh, and while you're celebrating said happiness, put a zip-tie on that hose.
Old Jun 3, 2012 | 03:35 PM
momostallion's Avatar
^^^^^ impressive!
not sure which way the pill goes but cobb sells a 3 port now and they have an OTS map for it. should offer better boost management.
Old Jun 3, 2012 | 04:15 PM
Thank god for the fuel cut, otherwise it could have been bad. I knew it was the FPR hose as soon as I heard the pop. ASC light came on and overboost code followed. Still not sure whether I should try reinstalling the pill or just switch to the LWG map. I place two metal clamps on the FPR hose hopefully they hold.
Old Dec 2, 2012 | 08:12 PM
Davidc44's Avatar
Run the lwg map
Old Jan 16, 2013 | 11:18 PM
woofmaster's Avatar
I ran the LWG map and still overboosted according to boost gauge and logs. I left the restrictor pill in (which I thought might lower boost but I'm not sure of the impact)
After IC install with LICP and UICP car felt slower for the week until Cobb Pro-tuned with 3 port in Dallas and its running much more consistent boost.
Old Jan 17, 2013 | 08:23 PM
3000GT-GTO's Avatar
Isnt stage 2 Target 26 PSI +- 1.5 PSI ?? That is what mine said on map note on 2012 stage 2 93 SF intake map. I occasionally hit 27 too but never experience any fuel cut, i thought that's still within the range of target boost.
Old Feb 26, 2013 | 08:24 AM
redragin's Avatar
just logged mine and i hit 28.5 psi. running stage 2 ots ams intake 93 octane map.
and mine dosent seem to have a problem with that. it also with me 27-28 psi at 4000 rpm then down to 16-17 psi at 6500-7000 rpm.
is that normal?
Old Mar 15, 2013 | 07:05 AM
Jyles's Avatar
is that normal?
I have the same thing. I have the AEM intake, Cobb Intercooler pipe kit, Forge BOV and Intercooler, and down pipe back cobb 3 inch exhaust. I have hit 28.8psi with the LWG setting and I have never removed the pill. My car runs like a demon and has no issues. I have the three port in the trunk waiting for the tuner shop to install and re map the car. BUT i haven't had any mechinical issuses...
Old Apr 4, 2013 | 10:01 AM
mshilto89's Avatar
is that normal?
I ran into the exact same issue last night doing some pulls. ETS catback and stage 13 maps. I flashed over to the LWG map, gonna see if it gets better...
Optiblue
26
Feb 20, 2014 01:05 AM
deadbeatrec
Cobb AccessPORT
Apr 30, 2013 04:28 PM
m3typer
Nov 3, 2012 01:22 PM
Get Rad
Feb 19, 2012 11:07 PM
robyn402
Sep 12, 2010 11:43 PM
