Buying COBB ACCESSPORT for 2012 GSR - QUESTIONS
Old Apr 12, 2013 | 04:39 PM
mygsr's Avatar
Post Buying COBB ACCESSPORT for 2012 GSR - QUESTIONS
EDIT: SORRY GUYS thanks for all the answers but turns out i dont need the ap. i canceled the order on it since the tuner said i dont need it and they have their own system. thanks all
Hey guys I have 2012 GSR ready to buy a COBB ACCESSPORT.
First of all, my parts that I have are:
(1) - AEM Cold Air Intake
(2) - AMS Upper Intercooler Piping
(3) - Synapse BOV
Does COBB create a custom map for me when I purchase or would I have to get it professionally dyno tuned?
Also, do I always have to have it plugged in while driving?
It is also a daily driver
Thanks
Old Apr 12, 2013 | 05:13 PM
mirkendargen's Avatar
No, yes, and no.
Old Apr 12, 2013 | 10:59 PM
Panda_stunter's Avatar
Cobb has off the shelf maps, if u want one customized for u, u have to get it tuned by a tuner on the dyno, road tune, or e-tune.
No, it doesn't need to be plugged in while ur driving unless u want to use it as a gauge: boost, knock, etc.
Unfortunately, Cobb does not support AEM intakes. I have aem intake as well, and I scaled the intake myself.
Old Apr 13, 2013 | 04:21 AM
mygsr's Avatar
thanks for your quick response,
if i just profesionally tune it, with the aem intake, will it still be okay or would i have to change my intake?
Old Apr 13, 2013 | 07:52 AM
atombomb33's Avatar
EvoM Community Team
They got rid of the AEM intake maps? They used to have them - but that was a few years ago and I haven't really checked on the Cobb maps in awhile, obviously
Old Apr 13, 2013 | 08:44 AM
Force-Fed Performance's Avatar
^^^ side note adam hope you are doing well man we miss you in NC
OP...there should be a cobb pro tuner in cali somewhere near you who can make a custom map for you.
Old Apr 13, 2013 | 08:56 AM
misterevo8's Avatar
get a custom dyno tune. depending where you are in CA, you can go to one of a few shops. IE Tuning Technolgies, Road Race Egnineerin, KT mortoring. give them a call.
Old Apr 13, 2013 | 12:14 PM
MisterHappy's Avatar
(3) - Synapse BOV
Thanks
No custom map, though they do have options for you to use of OTS maps. Possibly try the Stock box map and see if it runs okay for you.
Pro-tune is the best for you in this case thought, you will see more hp gains then OTS map would give you, plus it will be safer since it is tailored for your car. If you go to socal Cobb i believe you get a discount for buying the tune and AP together, but i may be wrong.
You can have it plugged in if you want to while driving, but you don't have too. It Nice to have it set up for a shift light or boost gauge, ect.
Old Apr 13, 2013 | 04:41 PM
mygsr's Avatar
okay thanks a lot guys, before i do the tune, im thinking about getting a downpipe. do you think its worth it?
also do i need a turbo timer? (my first turbo car)
and I would be going to FFTEC if i were to tune my evo
My options for a downpipe are:
1) ETS
2) AMS
which to decide!?
Old Apr 13, 2013 | 05:30 PM
mygsr's Avatar
Due to my head going crazy deciding which downpipe to get, i ordered the AMS WIDEMOUTH DOWNPIPE and COBB TUNING ACCESSPORT (Part number AP-MIT-002) this is correct yes?
Old Apr 13, 2013 | 09:40 PM
1) ETS
2) AMS
which to decide!?
Xs dont need turbo timers, and yes the widemouth added 10awhp to my E85 map.
Old Apr 13, 2013 | 10:41 PM
mygsr's Avatar
just the piping alone 10awhp with a tune or with a tune, but regardless thats big numbers!
do i need an exhaust or can i stay with stock exhaust because i want this car to be a sleeper
Old Apr 13, 2013 | 10:58 PM
Ikaika14's Avatar
I dont think FFTEC tunes AP.
Old Apr 13, 2013 | 11:18 PM
With a protune, u can get any intake u want. The tuner will scale the intake for u. U can also get an e-tune if anything. Which part of Cali r u from? SoCal or NorCal? SoCal has Cobb, hbspeed. NorCal has RRE (I think).
AMS downpipe will net u power. Actually, any one piece downpipe o2 housing combo will net u gains coz it eliminates the donut gasket which is the biggest bottleneck, other than the cat converter.
Yes, u can still run stock exhaust since most exhaust systems made are incorporated with the stock system in mind.
Turbo timer isn't really needed. Just slow down and don't wot on the last 5-10 minutes of ur drive and u should be good.
Old Apr 15, 2013 | 05:02 PM
mygsr's Avatar
OKAY Just called FFTEC. they said i dont need COBB AP. so im canceling the order since they have their own flashing systems.
"LANCER EVOLUTION X PRE-DYNO INSPECTION
-VERIFY AFTERMARKET MODIFICATIONS INSTALLED CORRECTLY (PER
HOUR CHARGE)
-BOOST LEAK TEST (DOES NOT INCLUDE REPAIR OF BOOST LEAKS)
-VERIFY VACUUM LINES INSTALLED CORRECTLY (DOES NOT INCLUDE
REPAIR)
-SPARK PLUG INSPECTION. VERIFY PROPER HEAT RANGE AND GAP.
-INSPECT TURBO FOR SHAFT PLAY
-INSPECT INTAKE FOR DIRT AND OIL
-INSPECT MAF FOR DAMAGE
-INSPECT VEHICLE FOR RATTLES (DOWNPIPE AND TRANSFER CASE)
-INSTALLATION OF WIDEBAND 02 SENSOR FOR TUNING (ONLY ON TWIN
EXHAUST VEHICLES)
FFTEC MOTORSPORTS EVOLUTION X BOOST CONTROL SOLENOID
BOOST SOLENOID INSTALL, EVOLUTION X
Genuine OEM Mitsubishi fuel pump relay for Evolution X
ECU DYNO TUNING DSM AND EVOLUTION 8-10"
for around 842$ sounds about right?
