tuning question
Old Feb 7, 2014 | 09:19 AM
alsong2002's Avatar
tuning question
My tuner was using accesstuner race to tune my car on dynopack, he was set on 315whp and 345wtq(he said he might need to set the tq lower because of the sst) this is not the final number yet as he will need to pull couple more pulls to see if the car is running good or not. my question is should he use the accesstuner pro from the begining? will i have higher numbers witht pro instead of the free race version? we are tuning it with 91pump gas. i understand that dynopack will read higher number than other dynos, will my number above seems little low? my mods are below.
__________________
performance:
Cobb v2
3.5" ETS intercooler with UICP and LICP
Cobb downpipe
Speedcircuit resonated test pipe
perrin catback
AEM intake
Turbosmart Bov
GM 3 port
Old Feb 7, 2014 | 09:36 AM
cravnpup's Avatar
With stock turbo cars ATP will not allow more power than ATR, though it does give the tuner the ability to tune as many cars as he likes. With ATR, you are married to the AP being used on the particular vehicle.
As for your numbers, it's hard to tell you without knowing your elevation, temp, correction factor, etc. SST cars will read lower than manual cars. One of the most important requirements for making consistent power with these cars is an accurately calibrated MAP/MAF. Is your tuner at least monitoring AFR's?
Old Feb 9, 2014 | 08:45 PM
alsong2002's Avatar
uh...i dont know if my tuner monitor afr as i was just behind the car when he is tunning.
but he did communicated to me of what he was doing on every step. all i know is he was doing lots of logging of the car. i think the log should included afr.
Old Feb 12, 2014 | 02:04 PM
cravnpup's Avatar
Ask whether he's calibrated the MAF for your intake. At the very least he should use the Cobb calibrations, though I've found that those aren't perfect. If you want some help or another set of eyes, PM me and I'll take a look at the tune.
Old Feb 18, 2014 | 08:42 PM
alsong2002's Avatar
here is my tune done today by ums tuning
https://www.evolutionm.net/forums/ev...l#post11120230
Old Apr 5, 2014 | 03:59 PM
Sj119808's Avatar
yea I'm having somewhat of a same issue. good luck man!
gtm_maxwell
Cobb AccessPORT
Sep 19, 2016 12:45 PM
JakeSoberman
Nov 30, 2015 11:28 AM
Destin_sinner
Cobb AccessPORT
Aug 6, 2015 03:56 AM
RallySport Direct
EvoX 'For Sale' External Engine / Power
Mar 29, 2013 08:26 AM
COBB Tuning
Mar 15, 2012 08:08 PM
