Mods, times and shifting
Old Oct 4, 2004 | 11:52 AM
ldstang50's Avatar
Currently I have the following mods:
Ported O2 housing, 3"dp, custom exhaust, aem intake, 700cc, 255lph, ebc, custom dynoflash, s-afc. I run consistent 12.5-12.6s (depending on weather) with a 60' always in the 1.65-1.68 range. ACT 2600 clutch, sorry.
This weekend I'm putting in ARP headstuds, cometic metal hg, kevlar tb, adjustable cam gears and 272/272 HKS cams. Then in two weeks I get the car tuned. Seeing that I have the s-afc and i have a goal in mind, 11.5s on stock turbo, do I get tuned with race gas? I think I should. Also at what point should I be shifting into 5th, if at all? I know 5th gear is a real dog so I want to stay out of it as much as possible. Right now I shift to 2nd at 6900rpm just before redline, every shift after that I'm shifting at 6600-6700rpm.
Old Oct 4, 2004 | 12:18 PM
Fabolusiconz's Avatar
Why are you shifting so early?
With my mods: SAFC, Ported and Polished Manifold and Turbo, Greddy Profec B, Custom Dynoflash, 3" Megan Racing Turboback, and an intake filter I ran a 12.4 at 111 with a stock clutch pulling off 1.70 60's. I normally shift right at redline so the rpms are probably at 7200 or so when I shift.
Old Oct 4, 2004 | 12:25 PM
ldstang50's Avatar
I was on the dyno back in March granted it was a lot cooler, my peak torque came in at 3500rpm with peak hp at 6800 rpm. Should I be shifting about 200rpm later. The days I've run have all been 83deg or more and very humid
ps: fastest time was on without s-afc, stock dp and stock O2 housing. That was probably the coolest day I've raced all summer. I honestly believe thats why my traps are so low
Old Oct 4, 2004 | 03:42 PM
Nad1370's Avatar
[QUOTE=ldstang50]I was on the dyno back in March granted it was a lot cooler, my peak torque came in at 3500rpm with peak hp at 6800 rpm. I honestly believe thats why my traps are so low
Your 272's will change all of that.
I see you got a custom flash. rev limit to 7800 rpm's ? You don't have to shift to 5th. 4th gear at 7800rms are around 122-125 mph
Race gas is a must if you want to run safe.
Also upgrade your stock intercooler. It'll heat soak by 4th gear.
Fast times BTW
Old Oct 4, 2004 | 06:53 PM
ldstang50's Avatar
ya i'm heat soaking as it is. My fastest time came in May when it was still kinda cool out. Nothing like the 50deg day when I got tuned. I think my car should be faster now that I have figured out how to drive it. I'm thinking given a much cooler day than I've run with so far I should be able to run a 12.3
I'm not really worried about heat soak in November when I go back to the track. But just incase my buddy has a nitrous express kit for the intercooler that I might be running.
KevOVIII
100
Jan 15, 2006 06:18 PM
Warrtalon
Oct 26, 2005 06:59 AM
NIevo
16
Jul 13, 2005 02:16 PM
cyberninja
Mar 29, 2005 05:55 PM
Rez90
10
Dec 29, 2004 04:35 PM
