Drag Rules w/trunk battery
Old Jun 15, 2005 | 01:51 PM
EvoTech's Avatar
OK I answered my own question. The following is taken directly from the NHRA website. Reading this sounds like I can mount it under the license plate.
Any car with a relocated battery must be equipped with a master electrical cutoff, capable of stopping all electrical functions including ignition (must shut the engine off, as well as fuel pumps, etc.). The switch must be located on the rear of the vehicle, with the "off" position clearly marked. If the switch is of a "push / pull" type, then "push" must be the motion that shuts off the switch, and plastic or "keyed" typed switches are prohibited. Also, the battery must be completely sealed from the driver and/or driver compartment. This means a metal bulkhead must separate the trunk from the driver compartment, or the battery must be located in a sealed, metal box constructed of minimum .024 inch steel or .032 inch aluminum, or in an NHRA accepted plastic box. In cars with a conventional trunk, metal can simply be installed behind the rear seat and under the package tray to effectively seal the battery off from the driver. In a hatchback type vehicle the battery box is usually the easiest solution, since the alternative is to fabricate a bulkhead which seals to the hatch when closed. At present, Moroso is the only company which offers an NHRA accepted plastic battery box, part number 74050.
But I drive on the street. I don't want a big cut off switch hanging on the back.
This solution takes a little work, but it solves the problem. Install the master cutoff inside the vehicle, positioned "sideways" so that the toggle moves forward and back. Drill a hole in the toggle handle, and attach a steel rod that will run out the back of the car, through a hole drilled completely through one tail light assembly. Have a spare tail light assembly on hand, so when you come home from the drags, you remove the rod and put the cherry tail light back in for street cruising. Next time you plan on going to the drag strip, swap lights and reinstall the rod. Since the drilled light is for the strip only, you can also have it marked "PUSH OFF" in big letters so the Tech Inspectors will think you're cool
Old Jun 16, 2005 | 12:20 AM
dgoodhue's Avatar
Battery cutoff are require for any relocated battery regardless of Et. You could be running 17's and it still require. Some track enfore the rule, some don't.
I have a battery cutoff in my truck and I made 2 brackets, one that hangs down below the bumper for the the track and another that tucks it out of sight for hte rest of the time. It take just 5 minutes to swap them. I have seen other creative solutions, behind liscense plates, tail lights, in place of license plate light.
RalliartN
Nov 2, 2015 08:57 AM
Insanity Evo
Dec 17, 2014 08:17 AM
UndeRated 8
10
Sep 2, 2014 06:24 PM
fasfour
Oct 5, 2010 12:17 PM
SWOLN
Mar 24, 2009 01:43 PM
