Well, here it is: 12.34@110.71
Originally Posted by EFIxMR
hey wartalon, are you flat foot shifting?
So do you constantly have to tune the SAFC or can you leave it alone once you find the "sweet spot?" I have a custom tune from DynoFlash and was thinking about buying a SAFC to fine tune it. I think my car is a fat up top, but I don't want to be costantly making changes.
After about 4 runs yesterday, I got to the point where my logs were just about "perfect," so I didn't change my S-AFC anymore. I didn't run any slower than 12.34 from then on...
Originally Posted by AlwaysinBoost
WOW! those times are awesome. what RPM are you shifting in 1-4th? If you get a flash it should raise your rev limiter.
btw, hows the clutch holding up after those 1.7s?
I then packed up and went home, and suddenly it was slipping a few hundred rpm on the highway in the higher gears when boost would build. I was still at 22-23psi on the 104oct, so there was a bit more torque than I'm used to, but even so, it was definitely slipping. I have to be honest about it...
I'm about to go find out if it was just slippery from being hot all day and while driving at highway speeds for a while after racing all day, or if it's just worn down to the end. If so, I'll be sure to relay that info.
The clutch was amazing...I did 20 passes in the last 2 days, all of which were 1.79 or better, and I never got any slippage. My last run yesterday was a 1.72 60' en route to a 12.24, and it held up perfectly.
You can bring it back though if you drive it for a few hundered miles like normal and were the "glaze" off the disk it should seat back and grip well again. But its only a matter of time before happens again. My clutch was so bad that even .1 bar of boost it would slip but with careful driving for a while I have it where I can make a full pull in 3rd gear and it doesn't slip. However in forth or fifth on the highway its a different story, no way to stop the slipping unless you s l o w l y roll into the throttle.
Anyway congrats again on your awesome times. Maybe some day you'll be up in the NE and you can give me some pointers.
I'm having the same problem now, I have over 100 passes on the stock clutch and its just starting to slip now in 4th and 5th gear with the stock boost solenoid in place. It all started about 4 weeks ago when I was at Island, I made about 15 passes most of which were 1.7's (finally got the lanuch down) then on the way home in 5th gear when I smashed the gas I noticed my RPM holding for a second before picking up and I knew the clutch was slipping.
Well I put my car on a Innovative wideband today. Doing a 3rd gear run from 60 mph to 7500 rpm and it was reading about 11.2 to 11.4 til redline i beleive. I'm not sure if I want to get a S-AFC now or not.
