New track times... I still SUCK
Well.. I got the car tuned a little better (Not too much) and now it makes plenty of power to get a mid eleven I am sure at 26psi or so. I pass the traps while bouncing off the rev limiter so every pass is either a 117.8-118.8 or there abouts. The crappy thing is my launching is not too great... 1.8-1.9 60' and I still can't seem to shift it fast enough. I run relatively consistant 12.3's.
I am figuring if I can get a decent launch of 1.6-1.7 and shift it faster I will be able to get somewhere around an 11.6-11.7 with the same power.. maybe faster with a way to not bounce off the limiter. Ill keep practicing I guess
And yes... the tuning is still not good at all. I am just now learning how to tune timing I can tell I am making more and more power everytime I make adjustments to the timing because i hit the rev limiter earlier
I also did want to ask how do people trapping over 118 get there??? Do you shift to 5th? What RPM do you get out of 4th at or do you just rev it to 8k or higher??
From: driving the 10 second beast in ohio or running lightmods.net
8000-8100 in 4th will get you 123-125 trap speeds..... thats why i am saying mph seemed low for anywhere near that setup or redline cause you said you were bouncing the rev limiter at 118 or 119 right
Yes the rev limiter is at 7750 and hits just before it from my logs and bounces the RPM's from 7.5-7.7 and it is at 118ish
I am afraid to raise the limiter any more without springs.
RPM, 1st 2nd 3rd 4th 5th
7500 41.1 61.7 85.4 116.9 167.2
7750 42.5 63.8 88.2 120.8 172.8
8000 43.8 65.8 91.1 124.7 178.3
So yes you are correct. I just dont know how much that would really help my times anyway.. obviously I am doing something horribly wrong to get my crappy ET's with that trap.
Originally Posted by TrinaBabe
Anyone got any pointers for a moron
This was my "best" run of the day:
1.806 60'
5.287 330
8.107 1/8
87.31 MPH
10.461 1000
12.386 1/4
118.20 MPH
I know my ****ing is really slow and for some reason I bog it between shifts also pretty badly. I also need to figure out a strange stutter type thing happening in 4th.. It may be slightly fouled plugs or something.. not sure yet. Hopefully it isn't some strange compressor surge type crap I dont know yet. I think my biggest problem on this run was the shifting and bog between shifts. But at least this is the info.
Im guessing because of the slow 1/8th mph I am losing alot of the time in the beginning of the track (1st to second shift mainly I assume). Well let me know what ya think
1.806 60'
5.287 330
8.107 1/8
87.31 MPH
10.461 1000
12.386 1/4
118.20 MPH
I had three other runs very very similair to these and they are all about the same.. plus or minus a few MPH in the 1/8th and .1 difference in the 60' but generally pretty damn close. I also do have a few crap runs like a 13.2 @115
1.806 60'
5.287 330
8.107 1/8
87.31 MPH
10.461 1000
12.386 1/4
118.20 MPH
1.806 60'
5.287 330
8.107 1/8
87.31 MPH
10.461 1000
12.386 1/4
118.20 MPH
its all in the shifts and boost response of the turbo (need to flat shift it without letting off) also you do have big power as you gained over 30mph in the back half
Well... I think I should be able to pull off 1.7's or even a high 1.6 with nothing else.. i have never set my tire pressure which someone told me may help by lowering it down a bit. Its around 34 in the front and 32 in the back for those runs. The car bogs badly between shifts and i havent figured out why. It is recirculated from an HKS SSQ BOV. I am flat shifting also using a fuel cut off at 5900. I am thinking I might need to slip the clutch slightly between shifts.. I think the clutch is screwy.. I may have warped it. It is an ACT 2900 and acts wierd on hard shifts.. I shift it hard and it sits for a few seconds before it seems to slam into the gear. Those are my guesses.
I also have no idea on the power it makes. My best guess is around the 450 mark which isnt too bad for my own retarded tuning attempts and only 25 psi. The car does get squirrly in 1st every once and a while on the track and only god himself would have the ***** to floor it in any gear from 1st to 4th in the rain.
