check out 1/4 times
check out 1/4 times
Did a couple passes at the track with my 05 evo in Arizona. Have a TBE, FMIC, K&N drop in and a ecutek flash for 91 pump. Track temp was about 85-90, what do you thik?
R/T .023
60' 1.946
330' 5.577
1/8 8.537
mph 82.61
1000' 11.089
1/4 13.232 @105.74
R/T .030
60' 1.947
330' 5.552
1/8 8.552
mhp 82.39
1000' 11.088
1/4 13.236 @105.63
R/T .023
60' 1.946
330' 5.577
1/8 8.537
mph 82.61
1000' 11.089
1/4 13.232 @105.74
R/T .030
60' 1.947
330' 5.552
1/8 8.552
mhp 82.39
1000' 11.088
1/4 13.236 @105.63
R/T .023
60' 1.946
330' 5.577
1/8 8.537
mph 82.61
1000' 11.089
1/4 13.232 @105.74
R/T .030
60' 1.947
330' 5.552
1/8 8.552
mhp 82.39
1000' 11.088
1/4 13.236 @105.63
R/T .023
60' 1.946
330' 5.577
1/8 8.537
mph 82.61
1000' 11.089
1/4 13.232 @105.74
R/T .030
60' 1.947
330' 5.552
1/8 8.552
mhp 82.39
1000' 11.088
1/4 13.236 @105.63
get your 60ft down to 1.6/1.7 and you should see a flat 13 if not a high 12
R/T .023
60' 1.946
330' 5.577
1/8 8.537
mph 82.61
1000' 11.089
1/4 13.232 @105.74
R/T .030
60' 1.947
330' 5.552
1/8 8.552
mhp 82.39
1000' 11.088
1/4 13.236 @105.63
R/T .023
60' 1.946
330' 5.577
1/8 8.537
mph 82.61
1000' 11.089
1/4 13.232 @105.74
R/T .030
60' 1.947
330' 5.552
1/8 8.552
mhp 82.39
1000' 11.088
1/4 13.236 @105.63
good job dude. did you run last night? I don't think that you will see a 1.7 with the rev limiter, my best is 1.83 using it. now all you have to do is buy my greddy profec b spec 2 and put in some 101 and you'll hit 12s.
. I was picking up my time slip when it went boooooommmmmm. I hope the guy has a very understandable insurance co.
I shift at about 6800 rpm, the power drops after that
Nope
Originally Posted by smp3000
I haven't seen you around I don't think. I live in Gilbert.
Yes, but only slightly. You're shifting way too early. If you shift at 6800, then you're too low in the powerband of the next gear. You should shift at 7200-7300...
