Went to the track....Stock 05 1/4
Old Oct 12, 2005 | 08:53 AM
DCSilvrEvo's Avatar
Originally Posted by Jacoby
Anyone else want to see slips before they believe it?
yea because I was hitting 12.7 @ 106...
Old Oct 12, 2005 | 08:58 AM
Jacoby's Avatar
And I am a bone stock 05 hitting 13.59@101. (Also with a 2.0 60ft time) I have vids to prove it.
Granted I have a SSL evo weighing a bit more but still a 106 trap is just way too high for me to believe without seeing proof.
Old Oct 12, 2005 | 09:05 AM
anjapower's Avatar
now that you mention it....yes. I'm starting to have my doubts. 106 is too strong for a stock Evo.
Boltz.'s Avatar
FCOTM Winner
Well I am actually late to class as is. My class started at 11am and its now 11:03 so Im a few minites late. So I'll have to scan the slips later...
Anywho, this actually did happen. It was @ GLD last thursday, same day that that white SC300 did a 9.5 and broke some record. I feel no need to lie on a public forum, slips come later tonight.
Old Oct 12, 2005 | 09:40 AM
Jacoby's Avatar
I am not calling BS. But when you make a claim out of the ordinary be prepared to back it up.
I also ran at GLD.
Here is my run. http://users.dls.net/~jjacoby/EVO/Run4.wmv
Old Oct 12, 2005 | 09:41 AM
gsujeff55's Avatar
thats atleast 3mph faster than ANY stock evo EVER.
i ran a 12.6@106mph...so, if you are hitting that mph you have quite a lot of room to work with on your ET.
Old Oct 12, 2005 | 10:26 AM
Boltz.'s Avatar
FCOTM Winner
I didn't realize it was that quick. Don't most of you notice that the better the 60' the lower the trap speed? I'd be pretty shocked to trap 106 again after hitting say a 1.7 60'.
I understand you guys aren't calling B.S. yet, but regardless I'll be posting the slip up tonight.
I'm hoping to hit the track this saturday again to see what I can muster out. I was actually planning on going tuned on ECU+, but my stupid expansys cable that I bought new never worked from the get go. So looks like I'll be trying stock one more time.....
On another note for those with '05s how do you disconnect the 5k limiter? I followed the clutch pedal to the switch that regulates this and disconnected the plug for it on my friends evo. I thought it was going to work at disabling the 5k rev limit because the car would start without the clutch in but when he actually got to the track, the limiter was still in tact (he told me)....
I thought that this was the proper way to do it?
Thanks guys
Old Oct 12, 2005 | 10:55 AM
Warrtalon's Avatar
No, that's the wrong switch. There are _3_ switches, and that's the easiest one to find. The next one up is for cruise control (inactive), then the highest one up (hardest to find and reach) is for the 5k limiter. It works just like the one you disconnected, but goes to a different switch.
I'm also completely baffled as to how/why you did that launch technique with the e-brake. I can't imagine why in the world someone would do something like that on their very first time running an Evo at the track. It certainly doesn't sound like that was your first time...I can't imagine anyone attempting something that complicated their first time. Then, to think you actually launched hard with only a 2.0 doesn't make sense either. You had to have bogged heavily to get that 2.0 unless this is all a big sham.
Anyway, the notion of great 60' times getting lower traps is true but not in your situation. What people normally see is that if they go from a good 60' (say 1.70) to an even BETTER 60' (say 1.65), they will get a better ET and POSSIBLY a slightly lower mph. This is caused by getting to the same distance in less time, and thus less mph. When comparing a 2.0 to a 1.7, this is not the case. When doing a 2.0, it means something went awfully wrong on the launch (complete spin with 0 traction through 1st and part of 2nd, a terrible bog, or no launch at all). These factors negatively affect both ET _and_ MPH. You would not have gotten better mph from a horrid launch like that...it would be much lower than normal (normal being 103-104).
Another example is that I ran 12.83 @ 106.3 with a tuned S-AFC on a good launch (1.76). What you're telling us is your car is as fast stock than mine was tuned. I also ran 12.64 @ 106.00 once and 12.64 @ 107.2 with s-afc/mbc/cat-back. At this time, I dyno'd 282whp on a Dynojet. This would mean your stock 05 dynos at least 270, which is hard to believe, but not altogether impossible.
I guess the question no one has thought to ask is...were you on 93oct?
Old Oct 12, 2005 | 11:00 AM
NoTec's Avatar
He stated it was on 93 octane in his original post.
Old Oct 12, 2005 | 11:04 AM
gkania's Avatar
Maybe Mitsu forgot to put the the front axles in, and he's got a rwd evo. Crappy 60 foots and higher traps. LOL!
Old Oct 12, 2005 | 11:41 AM
Warrtalon's Avatar
Yes, but I wanted him to think a little HARDER in case he forgot about the race gas he tossed in there...
Old Oct 12, 2005 | 12:56 PM
Stinkapuss's Avatar
Damn, my stock 05 only trapped 100.
Old Oct 12, 2005 | 02:38 PM
Boltz.'s Avatar
FCOTM Winner
This was absolutely my first time at the track. I've only had the car since sept 22. But I consider myself a good driver and I've had a lot of experience working on cars before owning an evo.
I've never put a drop of anything in the tank other than BP 93 and Shell 93 occasionally. The car was running 100% BP 93. No toulene, no xylene, no bottled octane boosters, no B.S.
I attached the picture of the slip, it doesnt scan very well so you have to look pretty hard to see.
Attached Thumbnails Went to the track....Stock 05 1/4-slip222.jpg
Old Oct 12, 2005 | 02:40 PM
Boltz.'s Avatar
FCOTM Winner
Yea it looks pretty hard to see. Ill try it again...
Attached Thumbnails Went to the track....Stock 05 1/4-slip.jpg
Old Oct 12, 2005 | 02:52 PM
IEXCELR8's Avatar
Was that your first time scanning also, I tried to fix it.Need better quality and not in rgb mode.
