Best cam gear settings for 272's at the stip?
Old Nov 10, 2005 | 07:42 PM
rACerS's Avatar
I was just wondering what you guys are running your cam gears at. And laugh if you want, but if your standing at the passenger fender the intake cam is on the left and the exhaust on the right. And if you turn the cam gears to the right that would be advancing them?
Right now mine are turned 3 to the right, and 1 to the right of straight up. So would that be +3,+1?
Most I have read about cam gears and 272's is to run them at -4,-1 or -3,-3. So if Im at +3,+1 that would mean more bottom end and less top end right?
So im hoping that changing these settings will get my mph up some. Im headed to the track this friday and would like to try some different settings. So will changing the cam timing affect your afr's?
thanks
Old Nov 10, 2005 | 08:16 PM
Warrtalon's Avatar
I don't know the specifics of how/why it works like this, but my buddy with 272s on his MR has the cam gears set to -4/-1, and he has a lot less low-end/mid-range power, but he has very nice top-end power as proven on the dyno. With these settings, he was able to trap 113.9 on pump gas the same night I hit my 12.01 and trapped 113.7 on race gas. Now, I don't have cams, but he still outrapped me despite being an inexperienced drag racer. He only hit a 12.6, but nailed right at 114mph on pump, which I think is a testament to the -4/-1 setting at the dragstrip. This was also at normal street boost of 21psi. We look forward to tossing in some race gas, cranking the boost, and leaning out the SAFC to see if he can hit 117mph. You can probably do the same with -4/-1 on the cam gears...
Old Nov 10, 2005 | 08:40 PM
rACerS's Avatar
thanks I will try the -4,-1 I will just have to figure out which way is - ahah
Old Nov 11, 2005 | 09:53 AM
gkania's Avatar
You would turn the cam to the left 4 clicks before 0 and 1 click before 0 looking from the passenger side. Just imagine you are looking at a number line.
-5 -4 -3 -2 -1 0 1 2 3 4 5
I
I
The line should be here for -5, I cant get it to stay by the four
Old Nov 11, 2005 | 04:58 PM
rACerS's Avatar
Thanks that helps a bunch
Old Nov 13, 2005 | 08:01 AM
matt55's Avatar
I like -4/-1.5 with 272's
Old Nov 13, 2005 | 08:15 AM
Nesiop's Avatar
I thought you needed some kind of tool to measure cam gears, or the dyno in order to just "turn the Gear" without taking a chance of damage. Or are cars for cam gear timing the same for all evos where as the tune is different for every car. Cause I am about to put in cam gears next week but was going to leave them at 0 0.
Old Nov 26, 2005 | 08:48 AM
rACerS's Avatar
Big thanks Matt, those settings worked great.
Old Nov 26, 2005 | 06:24 PM
Noize's Avatar
EvoM Administrator
Careful changing cam gear settings without remapping. It can cause lots of problems like detonation. I like -2/-1 the best.
Old Nov 26, 2005 | 06:33 PM
Warrtalon's Avatar
He switched to -4/-1.5 and went from 114.5mph to 119.5mph, so I guess it worked pretty well...
Old Nov 26, 2005 | 07:03 PM
DSMotorsport's Avatar
I have my gears set to -4/-1 and my stock 03 turbo is making much better high rpm power than I was expecting: about 385-390whp and it holds 375+whp from 5700rpm till 7700rpm. Im expecting the car to run 117mph on 93 pumpgas. no meth.
I haven't had time to experiment with other cam gear setting other than 0/0 and -4/-1 and the retarted settings seem to make significant high rpm gains.
Old Nov 26, 2005 | 07:07 PM
pharmd98's Avatar
Sorry to interrupt but anybody found a good setting for 280 cams?
Old Nov 26, 2005 | 07:25 PM
Warrtalon's Avatar
What is allowing you to make ~390whp on the 03 turbo without alky, race gas, or nitrous?
Old Nov 26, 2005 | 07:28 PM
vboy425's Avatar
i would say AEM EMS and Nitrous
Blue Evo 8's Avatar
GT35R
