New Track times and AEM vs. Stock ECU
Old Nov 27, 2005 | 08:30 PM
  #31
EVOfunk's Avatar
Originally Posted by fromWRXtoEVO
I concur with your statements. Putting a $1700 AEM with the appropiate tunning to get only .3 sec quicker and 3 mph faster is not that big of a jump specially when you add the race gas.
I average 2MPH extra and .2sec quicker when I add two or tree gallons of 99OCT to my already 91 OCT gas tank. That is with the stock ECU and at 3100feet elevation and 100degrees.
I am positive that if I can get .2sec and 2mph faster at the track here in Tucson I could also had gone .3sec and 3mph there with the c16 gas no doubth about.
So basicly the AEM and C16 did not do much unless we are missing soemthing else that it hasn't been discovered yet, that is why I don't want to speculate yet but pound for pound that AEM with C16 equals similar achievements on 100oct and stock ECU downhere at 100 degrees and 3100 feet elevation.
My .2c
Carlitos,
...actually he was running .2 slower with the stock ECU + race gas. (12.2 vs 12.0 I believe). Therefore the difference of running C-16 with the stock ECU and the AEM was .6 sec. (11.6 vs 12.2) That's a lot.
Old Nov 27, 2005 | 08:41 PM
  #32
Smogrunner's Avatar
Originally Posted by EVOfunk
Carlitos,
You are being foolish. Read carefully and you will see why. Don't make me sick Warralton on you.
Ah hell, let me spell it out for you:
His AEM was specifically tuned, thus optimized, for race fuel.
His stock ecu was tuned for pump gas, not race fuel. If it was properly tuned for race fuel it would have made around 30 whp more than pump gas. As it was, he ran a 12.0 on pump. With a proper race fuel tune, he definitely could have done at least an 11.8 @ 115.5 (maybe a tenth better).
So, his AEM could be attributed to making a solid 2 mph and .2 sec difference. That is what the rest of us dolts have been seeing and doing on these boards for two years now. BTW, I think .2 sec and 2mph is a great improvement!
Old Nov 27, 2005 | 08:50 PM
  #33
DynoFlash's Avatar
Originally Posted by PHILLY EVO
The car was tuned on by Al on 93 oct. I am happy with his road tune as AL Always does my stock ECU. I did put c16 in on the stock ecu made a few runs and played with the boost but the car was not tuned for that.
The AEM was tuned by Nick at the Evo vs. Sti at Englishtown and I ran 11.9 but had a boost leak. I run my car hard I had the Boost turned all the way up on my last 6 runs as I always do when I put c16 in for the past 2 years.
I LOVE the TME 6.5 that I got from Bushur great turbo but I want to get his 20G.....
I took the valve cover off today and there were some deep marks on top of the exhaust valve the first cylinder and little shavings. All the rocker are ok I should have the head off on Wed. I first thought it was a ROD KNOCK but when I got back to the pits and checked it out I thought a lifter or vale floated....the noise was coming from the head...... Hoping the valve did not hit the piston.
I will use my Stock ECU as my daily driver but when it is race time I will just plug in my AEM...I just dont like the cold starts on the AEM And I want to get my car into the 10's on the stock ECU I know Al can tune it to do that. I will bet getting a stroker motor Told the wife the motor was done so after the Holidays The car will get done........
Honestly - it pains me to see you have any problems wih your car
I still remember the 1st time we met at ATCO
Phillyevo is a classy guy and a guy who loves evos
BTW - I have your tune saved - when you have a chance - send me the stock ecu I would like to add the new anti lag two step feature to your ecu. With a better '60 foot you would have been in the 11's on your pump gas map which is a great accomplishment. I think the two step will improve your 60' times - although at thsi time of year traction is hard to find.
Old Nov 27, 2005 | 08:53 PM
  #34
EVOfunk's Avatar
So, his AEM could be attributed to making a solid 2 mph and .2 sec difference. That is what the rest of us dolts have been seeing and doing on these boards for two years now. BTW, I think .2 sec and 2mph is a geat improvement!
I was aware of all that: stock ECU was tuned for 93 and AEM for race gas.
I just wanted to show the instantaneous improvements he got by switching from one to another.
I also think that the AEM would've make a .2 sec improvement over a stock ECU tuned for race fuel.
  #35
DynoFlash's Avatar
Funny bro !
Old Nov 27, 2005 | 08:59 PM
  #36
EVOfunk's Avatar
Scary enough. Yes.
Old Nov 27, 2005 | 09:20 PM
  #37
timzcat's Avatar
My last two runs I was trying to set up my 2 step launch but the aem would not hold so I think I put my rev limit at 9000 and when I flat shifted it did not help and I also had a run when I missed 4th gear so I will be pulling off my vale cover today and see whats wrong.
I see the pictures now in the first post.
Honestly I think it can be only one of two things. You either over-rev'd and floated a valve and it made contact with the piston. (most likely bending it)
Was the rocker on the valve properly. The pics are hard to tell but looks like it lay have been hitting the spring retainer.
Can you push that lifter in?
Oh and if you decide to get rid of the AEM let me know, I am in the market.
Old Nov 27, 2005 | 09:47 PM
  #38
fromWRXtoEVO's Avatar
Carlitos,
Please post in english only.
Sergio, yes I know he went .2 sec slower but if we take the first run on pump gas we can see this guy already ran a 12.0 so the difference between the 11.64 to the 12 flat is a mere .3sec.
Anyway, what I trying to say here is that we are not sure why his car ran slower with the race gas and stock ECU. For the most part most of the EVO running higher OCT gas ussually run a few tenths quicker and a bit faster on the trap speed.
We can't determine for sure why he ran slower on the race gas stock ECU run, it could have been that he did not lauch well.
Most of the people on this forum would expect that if you are already doing 12 flat on stock ECU and pump gas that you would run a few tenth of a sec quicker and a couple of mph higher trap speed if someone does not believe ask Warrtalon or myself WE DO RUN FASTER ON STOCK ECU AND RACE GAS.
I am inclined to ssay that he had other issues with his car or that his car was not launch agressively or shifted properly.
Sergio, even you were telling me that you were planning on running quicker by adding some race gas on your 93 oct tunning.. the .6 sec of difference that you are refreing to, yes , it is there but does not make absolutely any sense what so ever.
Ask Warrtalon or myself wich have run at the track more than 100 passes and we will tell you that race gas most of the times improve your horsepower, top speed,1/4 mile times and trap speed.
Vishnutunning made an extra 8whp on a dynomustang on a 03 Evo by switching from 91 to 93 no tunning at all, just baseline. I have many reasons to believe there was something wrong with it.
Would you think your car could run .2sec faster on 89 or 87oct? That is my point, I can't really speculate on why Phillyevo ran slower but in normal conditions he should have run faster which brings me to the same topic. If he would have run in normal operating conditions he should have been in the 11's on stock ECU and race gas wich again it would demonstrate that the AMS $1700 toy would have give him a mere .1sec improvement
Last but not least, would that guy(Phillyevo) had his car tune for 100OCT on a dynoflash he would had run a 11.6 already.
Carlitos
Old Nov 28, 2005 | 03:31 AM
  #39
PHILLY EVO's Avatar
Originally Posted by RREvo
The noise that is coming from the Head is it loud and is it like clicking clunking sound ?
Its sounds like a slight rod knock......
Old Nov 28, 2005 | 03:39 AM
  #40
Precision Dyno's Avatar
Originally Posted by Sean I
If you are having cold start issues with the AEM something is wrong, there is no way that is supposed to happen if you got a full remap. I love the aem and hate to hear this kind of representation about it. If you need it remapped I can take care of it for you once you email me the calibration or come to my facility in person. I can have that thing driving like a stock car perfect idle and driveability and safe tune.
Sorry to hear about the engine damage, it sucks.
Sean
Sean, I think we have that covered thanks.
But If I need a hand I will let you know.
Nick
Precision Dyno
Old Nov 28, 2005 | 03:40 AM
  #41
PHILLY EVO's Avatar
I remember that too If it was not for you my car would not be a bad a$$ toy today you tought me alot THANKS Al......
Old Nov 28, 2005 | 03:51 AM
  #42
dug-e-fresh's Avatar
Hey thanks again I was looking for you before I left to see If you knew what was wrong with my car. sylvester 31 that was the only time I seen from him too12.2
I will stop by on Sat. it's great to get paid and watch the races for a little. That sucks about your map But you are the first Subi that ever beat me HAHAHA. That is a great car hope to see it in the 10's
Michael just wanted to leave... he thought his motor was trashed, too. It was making no power on that map at all... AND it made some weird noises. But the compression test was perfect... and then we saw map 6 selected, lol! Needless to say, it ran like a raped ape after we put it back to #5.
Not to be cocky... but both of us hear that a lot. It saddens me to not see Subies do better than they do. Both our cars aren't exotic. Easily replicated set-ups. Oh well... thanks though!! Remember, the 2nd run, you beat me Dammit!!! lol!
Seeya Saturday...
def
Old Nov 28, 2005 | 04:04 AM
  #43
turboDan's Avatar
I would almost be willing to bet that the noise started to be heard after the 4th gear misshiftThat sux,hope it is just something small in the top end,but like David B. said
not likely,sounds like all the info given=spun bearing,but lets hope not,just hope it is something Minor in top end.Good Luck
Old Nov 28, 2005 | 04:55 AM
  #44
PHILLY EVO's Avatar
Just to be on the safe side I am going to get the whole motor done and putting the car back to all silver...........................
Old Nov 28, 2005 | 06:27 AM
  #45
well, I guess it will be a nice christmas present, good luck with it!
anyone here run the 284 cams? whats the gain over the 272s?
def
