first time to the track
Old Jan 31, 2006 | 12:44 PM
evo3matt's Avatar
so last sat (jan 28th) i took the evo to the drag strip for the first time ever. First run... 1.77 60ft, 8.0 1/8, and a 12.5 1/4. Was very pleased since its my first time ever, and i knew i could improve.
However, second run... got the notorious ACT lock out in 3rd gear. Ran a 12.9 @ 104... But coming back around... 3rd gear starts grinding every shift.... i figure the 3rd gear synchro is gone... on a 2 month old tranny... super... so i've been driving around skippnig third... and i'm trying to decided what to do.
TRE vs. SHEP rebuild....
or
New TRE Tranny
Problem is the evo is my dd and i will have a hard time being out a car for 2-3 weeks if i send my tranny off.. Any suggestions are welcomed!!!
Old Jan 31, 2006 | 12:56 PM
btuneallen's Avatar
New Tranny! Should be under warranty right?
Old Jan 31, 2006 | 01:04 PM
ddubb's Avatar
probably not after you've taken it to the track, but you might have to look into renting a cheap car while the evo is in the shop. that is what I would end up doing if that was me. You could try to get the work done under warranty at a dealer and maybe they have courtesy cars for you to use while they are working on it.
Old Jan 31, 2006 | 01:08 PM
evo3matt's Avatar
lol no warranty work, act clutch voided it, plus more power mods are on the way... don't know if getting another stock tranny would be any good
Old Jan 31, 2006 | 01:09 PM
btuneallen's Avatar
Use the Stock tranny.. it should be fine.
Old Jan 31, 2006 | 01:20 PM
GTSMWET's Avatar
Its stuff like this that freaks me out to do stuff to my car, but i do it anyways, Currently have Buschur staeg 1,2, and 4. w/ a new clutch and flywheel, hopefully this don' happen to me anytime soon
Old Jan 31, 2006 | 01:24 PM
worksevo8's Avatar
TRE is the way to go! If you call or email Jon and inform your situation, I think they will get out fast to you. I told them I needed it in 5 days and they did it! Great people to deal with also.
Old Jan 31, 2006 | 01:27 PM
Doogie Howser's Avatar
Before you spend any money be sure to readjust your clutch pedal, you can check it out at evomoto. http://www.evomoto.com/tech_info.php?tech_id=28
You should be able to get rid of the 3rd gear grind using this technique if not I would PM actman. Good luck.
Old Jan 31, 2006 | 02:56 PM
evo3matt's Avatar
thanks for the advice but i already tried that... adjusting a little driving around, adjusting more, until the clutch pedal was as high as it would go, still grinding... its the synchro..
Boost3dxEvO
Sep 9, 2007 06:14 PM
GT35REVO8
31
Apr 7, 2007 10:27 PM
streetrace12
14
Nov 20, 2006 09:00 PM
Stinkapuss
17
Aug 1, 2006 01:24 PM
Chris@nolimitmotors
Mar 31, 2005 02:37 PM
