guys with gt35r ?
Old Apr 30, 2006 | 01:54 PM
Turbojunkie's Avatar
guys with gt35r ?
just trying to find out what others are lauching at with a 35r. ive got a custom flash from al with launch control and it set at 6500. i think its to high. i spin all the time real bad. can you guys with a 35r or even a 30r tell me what rpms your lauching at and your technique? thanx
Old Apr 30, 2006 | 07:19 PM
nickracer9's Avatar
try lowering your tire pressure. how much boost are you building on the revlimiter?
Old May 1, 2006 | 06:26 AM
tire pressure at 22 front and 26 rear. im not sure if its building boost. i havent taken the time to look.
Old May 1, 2006 | 07:15 AM
theblue's Avatar
what kind of tires are you on?
you've got two directions to go... either more traction, or less power.
Old May 1, 2006 | 07:39 AM
Silver05Bullet's Avatar
launch around 5000-5200 thats what i always do and i dont have a gt35r
Old May 1, 2006 | 12:21 PM
TrinaBabe's Avatar
It really depends on how much traction your tires have, your suspension, etc...
I have launched mine really low with a long slip (5k) with around 7psi off the line which worked ok but sometimes I would get wheelhop and my clutch HATED it. Last time out I was doing 5500 which was still too low. Next time out I will start with a 6k.
I have street tires set at around 23 psi all around. (I normally cut high 1.6s or low 1.7s)
Old May 4, 2006 | 02:40 PM
fre's Avatar
fre
Anything below 6500 bogs for me. I have even tried 6300 and it still bogged. I use to slip the crap out of my clutch, but that results in (1.8+) 60 foot times. It is better to slip slightly and then dump. I rely on a good track prep to get traction. Last time I was down in Phoenix at Speedworld, they had the worst track prep ever and I ice skated off the line getting 1.9-2.0 60 foot times. I got one pass in the (good) lane and hit 1.78 or so, but I have hit as low as 1.63 on a well prepped track under the same launching conditions.
SneezyIX
Nov 17, 2007 05:16 PM
jaytengan
Driving Techniques
13
Oct 16, 2006 02:27 AM
redevo58
Driving Techniques
Dec 31, 2004 10:26 AM
redevo58
Jul 19, 2004 08:22 AM
LancerEVOmann
Apr 17, 2004 10:18 AM
