Optimal rpm launch for most torque
Old Apr 15, 2004 | 02:23 PM
LancerEVOmann's Avatar
I was wondering what the optimal rpm lauch should be for the EVO? A tuner shop told me 7000 rpm but a rep at Lancershop.com told me that between 5500 - 5800 rpm is the best because that is the most torque at launch for AWD cars. Who is right, if anybody?
Old Apr 15, 2004 | 02:40 PM
SterlingEvo's Avatar
After my flash (324tq @ 3400) I slip-dropped just under 6000 and spun all 4 advans on dry tarmac. Anything below that and the car stutters, and anything above that I don't dare do. It seemed like it was just about perfect for my car.
Old Apr 15, 2004 | 02:41 PM
I think it has a lot to do with how your torque curve is set up...
Old Apr 15, 2004 | 10:48 PM
Fourdoor's Avatar
It also has a lot to do with how much you slip your clutch.
If you let out the clutch too fast from a low launch RPM you bog the crap out of the car. If you let the clutch out too fast from a high RPM you get some wheel spin. A bog hurts your times worse than some wheels spin, so a higher RPM launch works better for drag racing in most cases. My best results are at right around 6K RPM with an agressive slip.
Keith
Old Apr 15, 2004 | 10:52 PM
nastea1's Avatar
i think i've tried everything at a stop light, i usually do it in front of the police station...
anyway, to the point
i found that 6500 for me was too much, all four light up i still get a 1.6 60"
but 5000 seemed to work better
Old Apr 16, 2004 | 08:20 PM
Nad1370's Avatar
same here - 6000 and a fast slip . works every time.
1.72 60ft stock clutch
Old Apr 16, 2004 | 09:42 PM
evotomig's Avatar
Last time I tried 7,000 rpm launches the car went sideways at the track; and its real abusive to the driveline.
Experiment between 5,500 and 6,000 and quick slip.
(slightly less shock on the driveline and excellent traction)
Old Apr 17, 2004 | 10:18 AM
AbusiveWombat's Avatar
quick correction...it's not the torque but the horsepower. Max torque is around 3500 but at that rpm the EVO does not have enough horsepower to break the tires loose.
Uscbryan
Sep 26, 2013 11:59 AM
GTR2009
11
Aug 28, 2009 05:06 AM
jrsimon27
Aug 2, 2008 09:03 PM
AutoMotoSports
Automotosports - Illinois
23
Jan 15, 2007 07:00 PM
Chris@AMS
88
Dec 12, 2006 12:46 PM
