are the torque limiters tables used on GSR ?
you mean clutch slip ? No I don't have clutch slip. I also completly disable the ASC
I wait for the stationary rev limiter to reach 2-3 times then I dump the clutch, sometimes it starts hard with a lot of wheelspin.
well if the torque limiters cuts boost then it should be reason why it does not have enough power to break the traction
You are dumping the clutch too fast and when it grabs it brings the rpm's down.
You need to be able to slip the clutch a little to get the car rolling and then let off the clutch completly. Don't slip it too much or you will burn/glaze the clutch.
Last time when I let the clutch slip I got a lot of clutch smoke (It's a stock clutch on a tuned evo), I don't know why is this problem on evo, subaru's starts perfectly if you dump the clutch.
I wonder why the guys from Vishnu are talking about a limiter on GSR
full article here http://www.edmunds.com/insideline/do...ticleId=125372
And if Pathak had removed the Evo's electronic measures that protect the drivetrain, which limit engine speed during standing-start launches, the quarter-mile would have been even quicker
Disabling the Evolution's stock drivetrain protection would make for even quicker launches, while tweaking its electronic throttle would make it more driver-friendly during daily use.
GTR2009
Aug 23, 2013 07:13 AM
COBB Tuning
31
Feb 26, 2011 03:48 PM
AIK
10
Sep 13, 2010 02:48 PM
