Torque Limiter
Old Oct 7, 2010 | 11:28 AM
jamie_v1's Avatar
Torque Limiter
Is it possible to remove the torque limiter on a EDM Evo X SST-300gsr ?
Old Oct 7, 2010 | 03:14 PM
fostytou's Avatar
EvoM Community Team
Can you read the ROM from the ECU? Is it a factory ECU?
Old Oct 8, 2010 | 01:14 AM
jamie_v1's Avatar
Yes it is a factory ecu i will upload the rom later but all i need to know is what to adjust to remove it
Old Oct 8, 2010 | 02:31 AM
tephra's Avatar
what exactly do you mean by torque limiter?
ie - whats your real problem?
Old Oct 8, 2010 | 09:37 AM
jamie_v1's Avatar
The Evo X sst-300 gsr has torque limiter in first gear to reduce performance how is this removed in the rom
Old Oct 9, 2010 | 01:54 AM
tephra's Avatar
what are your mods?
Old Oct 9, 2010 | 01:57 AM
NZEvox's Avatar
Ok I think I know what you want.
They limit the TQ by using different tables in the boost control section for 1st ,2nd and 3rd. these tables are called
1, Reactive Solenoid Base WGDC Map #3 (Low Gear Range)
2, Passive Solenoid Base WGDC Map #3 (Low Gear Range)
3, Boost Target Engine Load #3 (Low Gear Range)
They maybe called something slightly different in your xml
They are all under the turbo section of ECUFLASH.
If you copy and past the the ones labeled (primary) in to the ones with the (low Gear Range ) you should then be running close to the same boost (TQ) in the low gear range as you do in the higher gears
Old Oct 9, 2010 | 07:14 AM
jamie_v1's Avatar
what are your mods?
The mods are air intake/tbe with decat and a walbro fuel pump
Thanks for the info that is what i was looking for
Old Oct 15, 2010 | 06:05 PM
gunzo's Avatar
you do not want to do that ..
There is a REAL physical limit to the 1st gear on the SST .. you change it and you break it .. especially when the CELs are disabled
Old Oct 20, 2010 | 11:37 PM
jamie_v1's Avatar
The u.k sst 330 version does not have the limiter on from the factory
Old Oct 21, 2010 | 04:31 AM
gunzo's Avatar
neither can the UK 330SST make more than 320ftlbs of wheel torque..
the Limiters on the UK330 SSt is STILL there .. you're probably mistaking the lower boost on the 1st gear ..
Old Oct 21, 2010 | 08:37 AM
jamie_v1's Avatar
This is the u.k press release stating that the limiter has been removed on the 330
http://www.autocar.co.uk/CarReviews/...30-GSR/240293/
ineedboostman
Mar 27, 2017 04:50 PM
fvaldes
36
Jun 30, 2014 01:07 AM
babaz7
15
Apr 9, 2013 08:27 PM
worm~
Mitsubishi TC-SST Discussion
40
Aug 19, 2011 07:28 AM
twinturbogreg
13
Sep 16, 2010 08:52 AM
