Track Results-Bone Stock IX - 450miles
Originally Posted by Evo_Kid
Good Launch = 1.75 or lower 60ft.
Believe Me, as SOON as the weather Breaks I'll Be there :-)
Here you go (not as identical as I first thought, but you'll get the picture)-
1st run ever in my EVO-
60- 2.090
330- 5.814
1/8- 8.954
MPH- 79.28
1000- 11.662
1/4- 13.918
MPH- 100.33
2nd run ever in my EVO-
60- 2.013
330- 5.695
1/8- 8.767
MPH- 82.46
1000- 11.442
1/4- 13.657
MPH- 102.37
As you can see my launch improved slightly, but my shifting really improved, and I knew I could even do better, because I didn't do so great in the back half.
So my point is 11SECEVO stop panicking and calling out other EVO owners, your car is just fine. Your suffering from a case of not being a great EVO driver out the box. Welcome to the club, keep practing your shifting and your launching and you will be there.
60- 2.090
330- 5.814
1/8- 8.954
MPH- 79.28
1000- 11.662
1/4- 13.918
MPH- 100.33
60- 2.013
330- 5.695
1/8- 8.767
MPH- 82.46
1000- 11.442
1/4- 13.657
MPH- 102.37
Originally Posted by 11SECEVO
Yea I know, and Shifting..Well 1-2 was ~6900-7000, 2-3 , about the same, and 3-4, againat ~6900-7000....is that InCorrect??
Last night, I took my IX to the track as well. My only power mod is a test pipe and I am un-tuned. About 3000 miles on the odo. Never launched an AWD car before. I still need a lot of work.
Track conditions...August in Alabama = 85 degrees at night.
60'................2.000
594'..............8.233
1/8...............8.782
1/8MPH........81.93
I was satisfied with my numbers even though I know I need work on the line. I know the car has it, I've just gotta get it too.
p.s. The stock clutch sucks. This is news, I know.
1/8MPH........81.93
Originally Posted by saywhen
disconnect your rev limiter. If I were driving your car I would launch somewhere around 6-6.5. A good launch is below a 1.7x or faster. Good luck
Launching just takes practice.
Now 60' Besides I had FOUR runs in with a CONSISTENT 99something MPH, and it's a BRAND NEW CAR..so that tells me that MITSB must have CHANGED the ECU Programing to LOWER Stock Boost/HP I guess do to Warrranty Issues??
ANYBODY got any OTHER Brilliant Ideas why the Car isn't running the 102 MPH that it Should???? I Used 94 Octane Gas..Sea Level Track...Checked and TIGHTEND all the Boost Hoses....
Do they get Faster After 1000or so miles like a LOT of other brand??
And Perhaps,as someone here DID point out, my 2-3 Shift was only at 6900 or so, I i was said I should try 7100..should that help??
*EDIT* Forgot to mention... I was launching at the 5000 stock limit, didn't roast my clutch once that day.
Yes, your shift point was prolly hurting you.
You can't refer to VIIIs as one unit, because 05s were not the same as 03-04s. 05s and 06s run the same stock boost (20.3 -> 17), but I agree with you that it's absurd when he said something about Mitsu changing the ECU programming due to warranty issues - this guy is nuts.
A shift point of 6900 vs 7100 would not hurt him - it's insignificant.
