Track Results-Bone Stock IX - 450miles
PS: Back half mph has a lot to do with gear spacing, shift points, and where your power is. My car is a little tepid in the 1/8th, but picks up almost 27mph on the back half due to having to shift out of third just before the 660' trip lights.
Originally Posted by WrX Kila
Let me know how your car is doing couple of thousand miles from now!
Outside of that.... stop trying to over-analyze the situation. This is what you need....
practice, practice, practice, and when youre done with that .... more practice.
if you would have gotten a 1.6 60', your time would have been 13.1 as drag racing is all about the launch. it can be done on the stock clutch but this will prematurely wear it out quickly.
use your stock 5500 rpm launch rev limiter & slip the clutch quickly like a bike-do it too fast car will bog, too slow clutch will smell REAL bad. if u do it right, you will NOT have any clutch smell.
shift quickly into 2nd after the launch & carry the rest of your gears out to about 7200rpm.
the stock Advan tire is more of a road race tire so run about 20-25psi of tire pressure.
remove the restrictor pill out of the clutch line.
hope these tips help...
Dont take your restrictor out & just dont listen to DJ.
Also, just for ***** and giggles, do a compression test. I think you might have started beating on the car too early, not completely sealing the rings, leading to lower or uneven compession (FYI, IXs have different rings then VIIIs). This is just a guess though, not saying its the answer.
Originally Posted by Evo_Kid
The limited is @ 5000, not 5500.
Also, just for ***** and giggles, do a compression test. I think you might have started beating on the car too early, not completely sealing the rings, leading to lower or uneven compession. Think is just a guess though, not saying its the answer.
Originally Posted by teknishnIX
The limiter is 5000 for the 03-05 VIII. It was raised to 5500rpm for the IX. I'm sure his power is fine. He just needs practice.
Not on my and others IXs, but that was a rumor at first. Maybe it has to do with the different ECU revisions.
You can't refer to VIIIs as one unit, because 05s were not the same as 03-04s. 05s and 06s run the same stock boost (20.3 -> 17), but I agree with you that it's absurd when he said something about Mitsu changing the ECU programming due to warranty issues - this guy is nuts.
A shift point of 6900 vs 7100 would not hurt him - it's insignificant.
https://www.evolutionm.net/forums/sh...d.php?t=217034
Yeah bro, sorry to break it to you but everyone in here is right but you. Listen to Warr he is actually giving you some informative info. You're driving just plain sucks, and to be honest, is downright pathetic. That doesn't mean it can't be improved upon. I'm sure 90% of the people on this forum didn't drive that great the first time at the track with their Evo's also. Like others have said it is a difficult car to launch. So stop taking it so hard or making excuses as to why your times were slow, just accept it for what it is. And what it is, is that you drove you car poorly, therefore it performed poorly. No more, no less.
The limiter is 5000, not 5500.
There are always revisions, but they don't randomly make the cars much slower with those revisions. There are tons of different firmware udpates for 03-05s within the SAME year. Having potentially 3 for the IX so far is nothing special. Mitsu certainly didn't update the firmware to the point of making the IXs slower than 03s...
DJ, no way would he hit a 13.1@99 even with a 1.6 60'. You can't just subtract the 60' difference and multiply by 2...that isn't how it really works.
3000ways, you too have a misconception, and in this case, it's the back half mph. It's easily gaining 21mph, because it's already at such a low mph in the 1/8th (78). In stock form, my 05 picked up 24mph in the back half on 93oct. I did 8.4@80 en route to that 13.1@104. I now only pick up 22-23mph in the back half with an extra 100whp, because my 1/8th mph is so high (~90). The back half mph analysis can be skewed when the 1/8th mile mph is so low. It's much easier to accelerate from 78-99 than it is to accelerate from 90-113.
Originally Posted by 11SECEVO
Yea, I'm not worried about it....Hell with better Shifting and 500 or so more Break-In miles I'm SURE that 60-70 HP will MAGICALLY come back... :-)
I know WARTALON thinks so!!
