Launching and Boost
Old Sep 22, 2006 | 07:37 PM
EvoRicer's Avatar
Originally Posted by 11SECEVO
Here we go again...Read what I said:
"tried it about 10 times without slipping OR dumping" so it looks like i AM working the Clutch Correctly, I'm also holding a Steady 6100rpm...Tire Pressure is a little low though at 26PSI for Traction though, NOT allowing enough Wheelspin...
I'll bump them up to 38 or so and try again!!
It's not your tire pressure because I drag my Stock tires at 25 PSI...I drive normal with 35-38 PSI.
Old Sep 22, 2006 | 07:47 PM
11SECEVO's Avatar
OK then, with my 6100rpm and Slow Clutch release what's causing the BOG then??
Old Sep 22, 2006 | 08:41 PM
Warrtalon's Avatar
Sheer lack of skill. This is how you do it:
Warrtalon's 12.000
Old Sep 22, 2006 | 11:11 PM
4g63_24's Avatar
Warrtalon's 12.000
I agree with warr, you say that you launch with a slow releash of the clutch, try slipping it fast and I mean fast. Fast does not mean dump as well. Practice practice pratice you'll get it man.
Old Sep 23, 2006 | 06:49 AM
AlwaysinBoost's Avatar
I am pretty close to reading. if you want to come by my garage I have the cable and software to adjust your stationary rev limiter to 5800. thats where I put mine at and I get consistant low 1.7s with the best being a 1.700
Old Sep 23, 2006 | 06:53 AM
11SECEVO's Avatar
I would be ENTERELY Gratefull, and ALSO HAPPY to and WILL PAY YOU for your time...I don't suppose you could do any Boost/Timing Adjustments????
Old Sep 23, 2006 | 10:48 AM
Warrtalon's Avatar
He could adjust those, too, but do you want some random joe trying to tune your car? That's very dangerous. Also, changing the launch control point doesn't even matter. If you can't launch it from 6k or whatever with the launch control disconnected, then you have other issues.
Old Sep 23, 2006 | 12:13 PM
11SECEVO's Avatar
No issues, I Re-Connected the Launch Limiter, and THIS TIME, after doing some searching, found that if you Floor (or really get into) the gas while it bounces off the 5000rpm limiter you can REALLY build boost, so Oviously I tried that and built dam near 10 pounds of boost and WALLA, Car went SIDEWAYS Smoking all four and came out HARD!! Lowered the Tire pressure back down to 29psi, and this time only Slight Wheelspin and GONE!!!
Gonna run my buddies Turbo Buick tonight (Mid 12 car) that usually '60's at 1.75-1.80 with Drag radials and line up for a few 1/8th mile passes...We'll see!!
Old Sep 23, 2006 | 12:57 PM
KawRider's Avatar
I predict he will beat you. Change your Name to 11 + 3 sec evo.
Apex Hunter
Sep 15, 2015 10:21 AM
2LOFD3ATH
37
Aug 9, 2010 01:40 PM
Johnboy1065
19
Mar 27, 2007 02:32 AM
99AllTurbo
Dec 17, 2005 01:54 PM
1QWKEVO
May 26, 2003 07:18 PM
