Finally made it to the 1/4 GT35R 20n psi and pump gas
Old Oct 14, 2006 | 02:06 AM
RyanB@VelocitySource's Avatar
I finally made it to the track with car. Look up my name if you dont know what my setup is. people said my manifold sucked and wouldnt work but I think I did pretty damn good for 93 oct and 20 lbs of boost
best run...
60'...1.803 (spun bad)
330..5.005
1/8...7.659
MPH..93.99
1000.9.962
1/4...11.876
MPH.. 118.67
Old Oct 14, 2006 | 07:03 AM
AlwaysinBoost's Avatar
damn I don't know how I missed this thead before. Anyway, we both ran our 35r's on pump gas yesterday. Your results were a little better then mine but considering the amount of custom fabrication and additional high dollar parts you have installed I would hope so. That is not an insult in anyway either so please don't take it like that.
My best pass, out of 3 on pump gas was a 12.1 @ 116. I made a post about it earlier, you should check it out.
You don't happen to have a log showing your boost and A/F would you??
Old Oct 14, 2006 | 10:52 AM
I had the laptop in my car but the battery was dead and my power inverter ****ted out on me towards the end of the night so I couldnt log my runs. I looked at your thread and its crazy how similar our times were.
Old Oct 14, 2006 | 10:53 PM
Ted B's Avatar
However, for the sake of comparison, those performance figures are pretty much attainable with a 16G and 93 octane, but without all the mega-expensive fabrication, standalone, or additional lag.
Just FYI.
Old Oct 15, 2006 | 02:05 AM
Just FYI.
118 mph on 93 oct. with the stock turbo?
Old Oct 15, 2006 | 02:31 AM
mchuang's Avatar
It is very attainable on stock t with a flash instead of standalone, but who cares Tony made you a sexy setup.
Old Oct 15, 2006 | 05:51 AM
Ted B's Avatar
Correct.
Old Oct 15, 2006 | 06:23 AM
Creamo3's Avatar
Those are respectable times considering the 35R doesn't start singing until the higher psi range; get some racegas in there and see what you can pull out of the setup.
Old Oct 15, 2006 | 06:33 AM
Sharkbite2000's Avatar
I can't wait to see what mine does its been to long since i felt it.
P.S. none of you are running alk injection ?
Old Oct 15, 2006 | 06:41 AM
bigyellowevo's Avatar
Good times in my opinion. Regardless of what the stock turbo can do. For 20psi on a gt35r and pump gas, that's pretty good. Congrats.
Old Oct 15, 2006 | 06:54 AM
Jasil's Avatar
It's a solid time, when buying a 35R, the goal should be 10's@130mph+......if not the stocker is fine for 11's and 120mph traps with Meth or Race gas.... believe it or not.
Old Oct 15, 2006 | 08:06 AM
Ultimate CC's Avatar
Nice times for straight pump gas...through some race gas in there and lets see what you do...my buddies when 11.0 @131
Old Oct 15, 2006 | 08:12 AM
EVOB23's Avatar
See I don't think that is true. Maybe he wants a car that runs 11s @ 120mph with pure ease, at low boost and straight 93 octane. If you want to do that with the stock turbo you will need race gas/meth and spiking 30psi etc. Don't fool yourself saying yeah stock turbo can do thta on pump gas because that is bs you are running the same amount of boost as you are on race gas.
I say to the poster congratulations. I'm sure you can probably get a little more out of it as I say a simple bolt on evo with GT35R should be good for mid 11s @ 120-122 on straight pump and low boost but you are getting there.
Old Oct 15, 2006 | 08:25 AM
Turbojunkie's Avatar
dont forget his 60' was only a 1.8. most stockers will not come close to even 116 traps without netting a 1.6 or lower. if he had cut a 1.6 his et and traps would have far exceeded anyting a stocker can do. unless ttp is running him
Old Oct 15, 2006 | 08:47 AM
Stinkapuss's Avatar
Stock turbos needs high boost and race gas/meth to run consistant 11's. I think you did good with you 35r and low boost. A lot of people don't realize that the boost recovery between shifts outways the power sometimes and that's why et's don't match the mph sometimes.
