Went to the track!! (VIDEO'S INSIDE)
Old Nov 18, 2006 | 01:45 PM
ant_turbo's Avatar
7.78 1/8 mile
Got a LIL sideways in the burnout box.
My Other Run
Old Nov 18, 2006 | 01:58 PM
4WS Tuning's Avatar
y would u try to do a burn out... ur just messing up ur clutch for no reason..
if u were spinning through first and second okay... but thats just pointless
Old Nov 18, 2006 | 02:09 PM
Spec'd's Avatar
Was that Irwindale Speedway ?
Old Nov 18, 2006 | 02:19 PM
ant_turbo's Avatar
1st I have a upgraded clutch!!.. 2 sec I have have seen a difference between just rolling passed the burnout box and doing a quick launch to clean off the tires!!
Because at IRWINDALE SPEEDWAY they really like to spray alot in the burnout box..
Old Nov 19, 2006 | 10:46 PM
Gonzo0991's Avatar
mods?
Old Nov 19, 2006 | 11:03 PM
clarkkent06's Avatar
vid's not working...but can you drive around the burnout box and avoid getting that crap on your tires? i know at PR in washington you can drive around the box
Old Nov 19, 2006 | 11:05 PM
scott yo's Avatar
aint working for me either!
Old Nov 19, 2006 | 11:57 PM
Danny23's Avatar
island dragway and englishtown also for driving around the burnout box.
Old Nov 20, 2006 | 01:37 AM
ant_turbo's Avatar
255FP/HKS FILTER WITH INJEN INTAKE WITH UICP/TBE/MBC/ACT HDSS....And every time I race I use race gas 100/103...
And you can't really drive around the burnout box!! You will still endup driving in it!!
Originally Posted by Gonzo0991
mods?
Old Nov 20, 2006 | 01:46 AM
ant_turbo's Avatar
There working now!!
Old Nov 20, 2006 | 11:38 AM
SKILMATIC's Avatar
can you post your stats of the time slip? very nice run btw.
Old Nov 21, 2006 | 10:41 PM
ant_turbo's Avatar
Sorrry there in the trash,,,
Old Nov 21, 2006 | 10:45 PM
eve-slow's Avatar
Looks like fun.
Old Nov 23, 2006 | 02:40 AM
dsmfan95's Avatar
The 1/8th mile tracks around here suck. You pick up rocks and other stuff rolling through the staging lanes, so rolling through the water box and cleaning off the tires helps.
Old Nov 23, 2006 | 05:47 AM
nvr2fast's Avatar
Nice!
What launch technique did you use? I hear you bouncing off the rev limiter, did you set it to 6000rpm? Sounds a bit lower at 5000rpm?
And on green, did you basically floor the throttle and dump the clutch, or did you do something different?
Warrtalon recommends i think 6000rpm and letting the clutch out quick (not dumping), but on my Evo IX, if i do that the clutch just slips (yes i'm on stock clutch). I find if I set the rev limiter to 5000rpm, i still dont bog but I dont get too much clutch slippage either. I am guessing because the IX has more torque perhaps? I tried 3000rpm that doesn't work. I have yet to try 4000 or 4500rpm, but I suspect it may bog.
