Anything wrong with my launch?
Old Feb 2, 2007 | 01:28 PM
bvdawg13's Avatar
thats about right for stock
Old Feb 2, 2007 | 01:30 PM
o.e.boost's Avatar
well the good thing is your not dumping the clutch but you kinda want to let up the clutch closer towards the point of activation rather than all the way to the floor...it just seems your taking too long off the line!!!
Old Feb 2, 2007 | 01:33 PM
RAZOREXPRESS's Avatar
lauch sounds about right.......hows that intake work?
Old Feb 2, 2007 | 01:34 PM
Smike's Avatar
How to 2step (my tech):
https://www.evolutionm.net/forums/sh...75&postcount=4
Get rid of that intake, it is the worst for our car. Search and you will be answered.
And this should be done at the track. 2stepping on the street should not be done, and then you get number (talking 60's here) so you can see what you are doing...and improving.
Old Feb 2, 2007 | 01:46 PM
I have yet to install any parts.......except a lower gauge pod, and a TT.I've read alot of the posts,still haven't really figured where to start.
I carried it to the track once,my times were horrible.This is my first awd .Now i know how to launch it decent.
Old Feb 2, 2007 | 02:20 PM
Warrtalon's Avatar
Originally Posted by LMleet20
It sounds sick, I got it installed when I bought the car from the dealer.
He didn't asked how it sounds - you don't buy an intake for sound, you buy it for power gains. It may sound sick, but it's also making your car sick...as in unhealthy. It is the absolute WORST intake you can put on the Evo, and NO intake should be installed without a tune. You have about $600 worth of mods only to make less power than stock while harming your Evo.
We can't answer your question without a timeslip - your explanation of your launch method is a little too vague, and the only way you know if it works is when you see your 60' on the timeslip. Also, traction is much different on the street than at the track, so I'd suggest going to the track and finding out if your method works. There's nothing wrong with building 5-6psi on the stock 5k launch limiter - what did you expect to see?
Old Feb 2, 2007 | 02:21 PM
Warrtalon's Avatar
You really haven't figured out where to start with mods after reading a lot of posts? It's pretty much a consensus that you start with the same basic mods on any Evo. Check the link in my sig for details - those are the best combinations of mods for VIIIs and IXs to start with, imo.
Old Feb 2, 2007 | 02:59 PM
Smike's Avatar
replace my intake for a aem cold intake?
Well a MBC would have been a lot cheaper for the same boost control.
You must be new to turbos, CAI are really a NA mod. Did you notice the snorkel that was stock on your car? What do you think that did?
2 paths correction paths here: go back the the stock intake and stock intake box+snorkel + K/N filter OR go back the the stock intake and get a simple MAF cone adapter and cone filter + tune.
Old Feb 2, 2007 | 03:01 PM
Warrtalon's Avatar
Why in the world did you get aftermarket mods at the dealership? I didn't even know that was possible, but they really screwed you over. That's your fault, though, not theirs. They are just making money off a sucker, but you didn't do any research first or ask Evo owners/vendors what's best.
No, you don't waste more money by getting yet another intake. YOu put your stock intake back on, then you go get an exhaust and a tune (flash) while learning how to use your EBC. There's no reason to have that $400 EBC if you're not going to use it. You said you're at stock boost, but you can't run stock boost on an EBC. It has to be setup and configured to run a specific amount of boost, and your peak boost may be 20.3psi like stock, but it does not have the same boost profile through the powerband.
Jacks Transmissions
Jacks Transmissions
50
Feb 20, 2016 02:54 PM
2012_Evo_X_GSR
Feb 25, 2013 12:01 PM
CarPhoto.net
Driving Techniques
122
Aug 12, 2011 12:15 PM
EVO+IX+MR+SE
29
May 25, 2007 09:38 AM
jasburbak
May 20, 2007 09:08 PM
