Daily Driver IX runs 11's
Old Sep 21, 2007 | 08:26 AM
  #91
thatsMR2u's Avatar
i wonder if the IX has a shorter 4th gear than the VIII MR- raising my rev limiter to 8200 i was able to trap 122 in my MR
Old Sep 21, 2007 | 08:31 AM
  #92
mike1023's Avatar
Originally Posted by dudical26
There is plenty of clearance near the oil pan and all that.
It is possible that maybe something else is making the noise, but it only happens like I said when the clutch pedal is pushed in. I don't really know what else would be making the noise.
Even though you did not have the problem with your clutch - that is not proof that this is not being cause by my clutch. Also you had Cusco this is Exedy
I only revved it to 8200 RPM last time before the new fourth gear. That was also only in 4th gear going through the traps. Now I shift at 7500 and run through the traps at around 7300
The only changes since last time I ran are
UICP
MAF Pipe
Evo 8 4th gear
Clutch
I would not expect these parts to really add all that much.
My Et went down by .15 and my MPH went up by .74MPH
The temps were about 35 degrees hotter this time around compared to last time.
My launch was also worse this time - I still need more practice with the new clutch
Considering everything, I am happy with the gain. Like I said with this same setup and only minor minor tweaking and a better launch I am confident that I can get into the 11.5's
you do know Cusco and Exedy are same thing just diff color and name. LOL
Originally Posted by 596736
I don't know if you answered this already, but why aren't you using the meth kit?
yes, i have asked him this.
I want to see how far I can go with just pump gas. Once I get to where I want, then I will push it further with the meth kit.
whats your goal 11.5? dont push it to much.
but i know you i still think you have the meth on just for safty which is not doing anything.
Old Sep 21, 2007 | 08:38 AM
  #93
reggiesd's Avatar
wow that's awesome, on a side note, anyone here know how an evo viii would run with the same mods?
Old Sep 21, 2007 | 08:46 AM
  #94
mike1023's Avatar
well i ran with stock clutch and less mods with a 11.56 on pump
Old Sep 21, 2007 | 08:48 AM
  #95
TeStUdO's Avatar
I think he has a full weight VIII though. The typical Evo VIII isnt running 11.56's
Old Sep 21, 2007 | 10:38 AM
  #96
dudical26's Avatar
Cusco is the same as the Exedy twin - I don't think its the same as the twin HD.
Goal I said is 11.59 with this setup. Once I get that I will set new goal, maybe add some cams and see how I can do.
And I promise there was no meth or water or anything that day. Ask Burt he was there - did not even have the pump in the car since I was testing it on the workbench.
Old Sep 21, 2007 | 10:56 AM
  #97
mike1023's Avatar
wrong if you read back a while we know that his car is 150lb heavier then my. which is really not that much. when i was at track i had ~75lb added to car and then took it out and ran same time LOL. maybe .04 faster. which is not big at all. lol
i think with how his car is setup. with the build tran and better gearing. and lighter rims and rotors then me, since i had stock i have no dough that this car can go just as fast as me, if not faster.
what it comes down to is driver!
i told him once i tell him again when he is home im more then whiling to help him out and get him into the low 11s and even if he wants 10s. with what is done to the car is far more then my had. and also he keeps it very anle clean and up to 100% working order. my car was not like his LOL which if i keep my to how clean and stright it is my would of went couple .01 faster.
Old Sep 21, 2007 | 10:58 AM
  #98
TeStUdO's Avatar
I was replying to reggiesd's question. They typical VIII isnt going to run an 11.56, so dont jade him.
Old Sep 21, 2007 | 11:00 AM
  #99
mike1023's Avatar
wait a sec now i think about it, his car is even lighter now since he did more things to it. his car really should be right next to my. i remember when we did some rolls he used to be right next to me. i would have no douth i can get into that car and get a better time then mine.
reason: bigger turbo then evo8= more power. car is all alinded up nicely= no drag on car. trany has the best gear radio for drag racing.
hands down it can be done.
Old Sep 21, 2007 | 11:02 AM
  #100
mike1023's Avatar
LOL a lot of evos out there can run much better times its just that not every one can drive them.
when i go to track and see how many evos launch and shift there evos. i kind of get sick to stomach and want to help every one to drive there car to how it should be.
Old Sep 21, 2007 | 11:06 AM
  #101
dudical26's Avatar
The car weighs about 2950 WITHOUT me in it.
so it is still a bit more then you, you were like what 29XX with you in the car. So I'm about 150 lbs more like you said before.
Old Sep 21, 2007 | 11:09 AM
  #102
mike1023's Avatar
LOL come on alex you know your car is less then that. dont try and make your car heavy then what it is. i know your car and i know what you took out and put in. i did it all plus more. i have all the weights.
last time me and you were at track you were 150lb heavy, and since then you took out more weight.
Old Sep 21, 2007 | 11:13 AM
  #103
dudical26's Avatar
I was 3100 with me in the car tank with 1 gallon.
Since then added meth kit + 15lbs
Suspension - 19lbs
Firewall Sound Deadening - 8lbs
Total - 11
I have removed 11 lbs since last time
new total = 3100 - 11 = 3089lb
3089 - me(140) = 2949 lbs
There you go - Total weight without me is 2949
Old Sep 21, 2007 | 11:16 AM
  #104
mike1023's Avatar
Suspension - 19lbs
Total - 11
your coming home and going on the scale LOL and my car not much lighter anyhow LOL.
the fact is you can run the times i did with out a problem.
Old Sep 21, 2007 | 11:17 AM
  #105
dudical26's Avatar
I hope I can run the times you did, that would be very cool. Bottom line is though that I am happy with the car now and I'm just taking small steps forward.
