Daily Driver IX runs 11's
Old Sep 21, 2007 | 08:12 PM
  #121
kouzman's Avatar
Holly cow... You guys are LIGHT!!!
last time i raced i weighted the car at 3507 pounds with me inside!!! But i am heavy around 250 pounds so the car with less than half a tank is around 3250 pounds... need to go on a diet!!!
Old Sep 24, 2007 | 05:48 AM
  #122
mike1023's Avatar
Im 160lb naked!
Old Sep 24, 2007 | 05:11 PM
  #123
kouzman's Avatar
Originally Posted by mike1023
Im 160lb naked!
I guess need to go on a HARDCORE DIET... i am 245.... actually i lost 10 pounds since my last time at the track....
Old Sep 24, 2007 | 05:25 PM
  #124
cangriracing's Avatar
Does the intercooler in his car make a difference, i have read numerous times one doesn't need it till 400whp, but he is making really good times with it. Can someone explain this?
Old Sep 24, 2007 | 05:50 PM
  #125
dudical26's Avatar
There is no better motivation for loosing weight then to go faster.
Old Sep 24, 2007 | 05:52 PM
  #126
dudical26's Avatar
Are you talking about me or Mike, we both have Bushur Race IC's
Old Sep 24, 2007 | 05:59 PM
  #127
about yours
Old Sep 24, 2007 | 06:53 PM
  #128
kouzman's Avatar
HAHA
Its soooo true!!!
Old Sep 24, 2007 | 07:47 PM
  #129
dudical26's Avatar
I think the IC helps. You can read my review hereLINK
The stock one might be "good" up to a certain HP level, but that does not mean that an after market IC wont still help.
Old Sep 25, 2007 | 09:53 AM
  #130
mike1023's Avatar
well as you know the race ic, you get pressure drop. which means your little stock turbo has to work even harder to make that 1-2psi.
the reason why i went with the race is i want to see just how far i can go with the stock turbo and push it. and also i take car on street and race around on track so didnt want to get heat sock which is the worst.
i really have a feeling if i have the stock ic and cool it down i think i can run same or better time with it. just because the turbo does not have to work so hard to fill all of it. but then you run into the problem that it will heat up faster. so its a win win. also the stock and or smaller ic are lighter, well a lot lighter, when i got the ic i almost didnt want to but in car since it was so dam heavy vs the stock one. LOL
i would like to do back to back dyno runs. with stock ic, race, and some others.
Old Sep 25, 2007 | 10:10 AM
  #131
dudical26's Avatar
Thats a good point - the Buschur Race IC is 20 lbs heavier than stock.
Old Sep 25, 2007 | 02:46 PM
  #132
evovin's Avatar
20lbs=20hp
Old Sep 25, 2007 | 04:22 PM
  #133
dudical26's Avatar
I'm not sure if it makes 20hp, but I do think it helps.
Old Sep 26, 2007 | 05:41 AM
  #134
mike1023's Avatar
well its 20lb on the front end, take front end weight off is big.
dudical26
73
May 5, 2026 05:15 AM
94AWDcoupe
Mar 25, 2016 05:33 AM
tscompusa
Nov 19, 2015 02:36 PM
dudical26
51
Sep 9, 2012 02:02 PM
StreetThisEvo
Jul 2, 2012 04:55 AM
