Post your Evo Green Track Results
Old Apr 18, 2007 | 05:36 PM
  #31
Nvr2old32's Avatar
Originally Posted by 4 Wheel Slide
rev it out 8300 =-) the evo can handle it
Crap! My rev limiter is set to 8000. I guess I'll need to adjust that!
Old Apr 19, 2007 | 10:50 AM
  #32
Kee1pride's Avatar
mines set to 8100. but i doubt ill ever take it past 8k because i haven't done my valve springs and retainers yet. if you're going to go all the way to 8300, then i'd recomend you get them done.
Old Apr 19, 2007 | 10:58 AM
  #33
4WS Tuning's Avatar
i use to rev to 8500, until i got my taller tires, now i rev to about 7900-8000.. =-p
do it at ur own risk.... i have stock cams, my motors never been open. Factory seal so its pretty strong. =-)
Old Apr 19, 2007 | 11:09 AM
  #34
Kee1pride's Avatar
you ever fix that 30psi thing that your car was stuck on? what was wrong with it?
Old Apr 19, 2007 | 10:46 PM
  #35
HmanEVO's Avatar
Originally Posted by 04evors
I raced at Atco New Jersey about a month ago and wen't 11.52@121.1, first time out with the turbo. I was at 25psi. Last week I wen't 124.4mph @28psi at home but just couldn't put a run together. I also managed to lose a rear axle.
I am running dsmlink and was seeing 55lbs/min. I am very happy with this turbo.
Good to see another DSMLink user over here. You must be James? I see that you as well as several others are making some nice power with the Green. It's looking like FP got the recipe right with this turbo. Btw, 55lbs/min is insane! Just curious but what kind of airflow #'s were you seeing with the stock turbo maxed out? For a 50trim reference, this week I ran 11.5@125 at 28psi peaking 51lbs/min. Ambient temps were in the low 50/high 40's. If you wouldn't mind, I'd love to check out your logs from the track just to compare.
Chris
Old Apr 20, 2007 | 04:47 AM
  #36
94AWDcoupe's Avatar
Chris
DSMlink can flow false numbers when the maf scaling is off. Hes not actually flowing 55lbs from the 20g. Your 51lbs is off as well.
Old Apr 20, 2007 | 09:43 AM
  #37
04evors's Avatar
This is true! I found 55lbs/min. hard to believe....something was messed up through 1-3rd gear because in fourth airflow dropped to where it should be 47-49lbs/min. I log my wideband as well and through the 1st 3 gears my wideband was way off compared to the estimated wbo2 in DSMlink.
I was typically seeing 42-43lbs/min. on the stocker which was good for 11.5's@117.
Old Apr 21, 2007 | 08:01 AM
  #38
dsmfan95's Avatar
Power may be dropping off but there still is plenty of power still being made. I might give a shot at shifting at 7500
I have always had good luck shifting high.
It's up to you, every car is different. I've just found that if I shift slightly before the power starts to fall off, I get the best trap speed.
killerpenguin21
Sep 26, 2015 09:36 AM
BrettMR
Northwest Region
Apr 2, 2010 09:09 AM
afmafia
82
Apr 18, 2008 12:22 AM
JMB8606
372
May 4, 2007 04:16 PM
raced_EvoVIII
14
Aug 19, 2005 05:12 PM
