need some help
Old Apr 19, 2007 | 01:43 AM
evilevo22's Avatar
need some help
my trap speeds are all messed up i keep trapping 97mph. I trapped higher then this many times with less mods whats up with my car. Boost leak? spark plugs? need some help thanks.
mods are 3" tbe, ss o2 housing, licp, mbc 21psi, fuel pump, intake, act clutch/fly, ss clutch line. jestr mode 1 flash
also is power shifting ok on our cars.
evilevo22
Old Apr 19, 2007 | 05:19 AM
3000ways's Avatar
My opinion is you have a boost leak and yes power shifting is ok. Please post all the data from your runs, so that people can help you out better.
Old Apr 21, 2007 | 12:21 PM
evilevo22's Avatar
heres some slips
i still have the stock 8 bov would this be one of the problems? My launches werent that great because im a little afraid to break things so i think i was slipping the clutch to much.
sorry pics are probably too small ill post more later but heres the times
1.8 60'-------------------1.9 60'----------------------------1.9 60'
13.466 at 96mph-------13.6 at 97 mph-----------------13.6 at 101 mph
Old Apr 23, 2007 | 04:03 PM
evilevo22's Avatar
ttt
Old Apr 23, 2007 | 04:05 PM
bluebyu36's Avatar
do u run 91 octane?
Old Apr 23, 2007 | 07:37 PM
kouzman's Avatar
You are powershifting and yet you are afraid to launch hard??? That's crazy my friend!
Your bov might be leaking! the VIII plastic bovs are not famous on keeping boost over 23psi! Whats your 330?
Old Apr 26, 2007 | 12:13 AM
evilevo22's Avatar
no im not power shifting. I was asking to see if it was safe or not so i could gain time using it.
also on a 6 speed i hold fourth until i trap 116.
Old May 3, 2007 | 05:28 PM
evilevo22's Avatar
went back to the track with new intercooler and my best was a 13.214 at 99.4mph with a 1.85 60ft. My highest trap was a 13.298 at 103mph with 1.9 60.
what would these times be like with a 1.7 60.
Old May 3, 2007 | 06:05 PM
kouzman's Avatar
can you post the whole timeslip? or write down the details...
60ft
330ft
1/8 mile
1/8 speed
1/4 mile
1/4 speed
Old May 3, 2007 | 07:34 PM
Warrtalon's Avatar
You need to have the car inspected by someone who knows Evos. Have you installed fresh plugs, done a boost leak check, and a compression check?
Old May 4, 2007 | 12:11 AM
evilevo22's Avatar
no i havent checked my plugs. Thats why i was asking if it could be plugs so i know to check them. Ill run a compession test and boost leak test soon and post data.
what plugs should i look into for my setup
Old May 4, 2007 | 07:09 AM
Warrtalon's Avatar
You shouldn't have to ask if it could be your plugs. Just go and change them!
NGK BPR7ES or BPR8ES gapped to .026 or so. Start with 7s, and if those break up, then use 8s. These plugs only cost $1.50/ea, so you should always have plenty of spares ready. The fact you had to ask which plugs to get tells me you've never changed yours???
Old May 5, 2007 | 11:12 PM
evilevo22's Avatar
i put the bpr7es in and it ran fine then after driving a little my car started to fell like it was dying. I looked at a plug and it looked burnt. Should the bpr8es work. If not what other plugs will work
Old May 6, 2007 | 08:28 AM
Warrtalon's Avatar
Yes, BPR8ES will work, but if your plugs burned up like that, you might have a coil pack or spark plug wire problem. What you described should NOT happen.
Old May 6, 2007 | 12:49 PM
evilevo22's Avatar
ill take pics of the spark plugs when i take them out. Hopefully theres not something else wrong. I seem to have nothing but problems with this car.
the plugs that were in before were ngk igr7a-g. Then i put the bpr7es gapped .026 and car ran fine for like 2 blocks then started dying and running like ****. Will the bpr8es work or do i need diff plugs cuz i dont wanna have to go back to the store for more plugs again if i dont have to
