Drag Tires and Wheels?
Subscribe
Jul 10, 2007 | 01:49 PM
Just curious what people are using for tires at the strip. I'm not interested in hearing about all seasons or regular tires, but from guys that make enough power to have made the decision to go to a drag radial or slick. What wheel and tire do you go with? Is there something that will fit an OEM wheel besides the BFG 225?
I'm wanting to keep my stock brakes and suspension, so what are my options? I see BFG has a 225 17 and a 275 17 DR. It seems like all of the companies that offer a 17 inch drag radial only make them in a 275...and they are 26 inches tall. I know about the quicktime pros and ET streets but I don't have enough power to go through all that trouble. I am leaving the hole on a pretty big shot of nitrous and that is now causing me some problems in 1st gear.
So if you have gone to a drag oriented tire, maybe posting some of your info would help me.
-Tire and wheel
-WHP
-rpm and speed through traps
Thanks
Reply 0
Jul 10, 2007 | 05:11 PM
Sounds like you need some aired down (20psi) RA1's in a flavor that suits you. 255's have netted 1.6's for my friends and I am spinning 275's at 20 psi (air pressure in tire) currently and still getting 1.6's. Besides the fact that they arent really a drag tire, they did propel Shep to 9's for quite along time back in the day when he was that slow.
275/40-17 RA1 at 20 psi
5Zigen GN+ 17 x 9.5
4xx whp
I have run as fast as 8300 through the traps this year on just the Green (no bottle) and the timeslip was at 8100 or so at the line.
Reply 0
Jul 10, 2007 | 08:29 PM
I am more interested in guys running drag radials. I am cutting 1.64 - 1.68 60s on 235 Hankook Icebears @ 40psi. I put my shaved Advans back on and am blowing them off pretty hard, but I'm also spraying a larger shot. I'm looking for under 1.6s.
Should I just get the 275s and a wider rim? I like keeping my car looking stock so I was trying to avoid that.
Reply 0
Jul 10, 2007 | 11:20 PM
40 psi? If you can cut 1.64 with 40 psi you should be down lower with 20 psi. There are no real choices in a drag radial for a stock rim other than the 225.
Reply 0
Jul 12, 2007 | 03:55 AM
you could go with nitto 555r in 245/45/17...it will be off slightly but still better than 275/40's....
Reply 0
Jul 12, 2007 | 10:09 PM
the bfg's hook much better in 225 than nittos in 245..
Reply 0
Feb 12, 2008 | 12:41 PM
*bump* I'm in the market for a drag radial that will fit the stock rims
Reply 0
Feb 13, 2008 | 10:23 AM
i run BFG DR 225/35?17 tire psi at 22hot 18-19 cold.
note on a stock 05 rim.
at those time i had around 365hp - 375hp and 415tq
i get 1.5-1.6 every time with out trying.
this year i think i will try and go with a sticker tire.
also note with a really wide tire as in 275 in the upper speed it will slow you down. this is why you want a thin tire but sticky so you can go faster duhh lest friction pad on road.
Reply 0
Feb 13, 2008 | 01:45 PM
thanks mike
Reply 0
Feb 17, 2008 | 11:36 AM
are they still making them? i heard they where getting hard to get. (BFG DR 225/35/17) is this true?
Reply 0
Feb 19, 2008 | 08:53 AM
Quote: are they still making them? i heard they where getting hard to get. (BFG DR 225/35/17) is this true?
i dont think so lol tirerack your way to go.
Reply 0
Feb 20, 2008 | 01:54 PM
www.summitracing.com still has the 225/45/17 BFG's drag radials for around $155 each.
Reply 0
Feb 20, 2008 | 02:00 PM
I got mine here, 140.00 each and free shipping
http://www.discounttiredirect.com/di...08&rd=17&ar=45
Reply 0
Feb 20, 2008 | 02:03 PM
http://www.tirerack.com/tires/Sizes....FA+Drag+Radial
they have them for 143$
when i got them back a year ago they were 131 LOL
Reply 0
Feb 20, 2008 | 09:09 PM
mellon, how recent did you buy your tires?
Reply 0
