Shift Point discussion, 7K or higher for MR's
Old May 29, 2008 | 11:34 PM
Mr. Evo IX's Avatar
I went to the dragstrip last night with my Evo and logged all of my runs. One of the things I wanted to try to discover was what effect using different shift points had on my car. I was able to create an interesting visual from the log.
These HP / TQ figures are derived from airflow/rpm instead of time/distance/work calculations.
2byte rpm values
1st 7558
2nd 7878
3rd 7886
4th 7843
Conventional Evo wisdom, stock turbo doesnt make usable torque above 7K. Airflow may say otherwise. Discuss.
Old Jun 1, 2008 | 03:05 PM
Carloverx's Avatar
Do it again but shift at 7k. Compare the two graphs. Right? I can't wait to see the results
Old Jun 1, 2008 | 04:08 PM
Mr. Evo IX's Avatar
The next time I go to the track I'll make sure to get it both ways and I'll update the thread and PM you. Note not all cars have a powerband like mine so this may not change conventional wisdom. I wasnt looking for an argument with Warrtalon in your thread, I'm looking for my ideal shift points too.
Old Apr 11, 2009 | 09:06 AM
Carloverx's Avatar
bump for results haha
Old Apr 11, 2009 | 09:00 PM
C6C6CH3vo's Avatar
I get my fastest splits shifting at about 7000. stock turbo
Old Apr 12, 2009 | 02:38 AM
PeteyTurbo's Avatar
You look at your dyno chart and go from there
Old Apr 12, 2009 | 03:40 AM
Levar's Avatar
Veteran: Army
I'm not going to simply say 7K and that's it. I'm more practical by weighing all of the necessary and required numbers to make the best decision. If you have a dyno chart of your tune available, this website should give you a hand.
http://www.bgsoflex.com/shifter.html
If you need the transmission gear settings for your car, here they are:
Gear Ratios
EVO / EVO RS
1st: 2.785:1
2nd: 1.950:1
3rd: 1.444:1
4th: 1.096:1
5th: 0.761:1
Final Drive: 4.529:1
Gear Ratios
EVO MR
1st: 2.909:1
2nd: 1.944:1
3rd: 1.434:1
4th: 1.100:1
5th: 0.868:1
Final Drive: 0.693:1
Old Apr 13, 2009 | 07:35 PM
Carloverx's Avatar
Yeah i hear ya, but my power curve is soooo gradual but gaining and loosing hp
kiggly
Jan 22, 2011 08:28 PM
LaXGSR
Apr 11, 2010 11:10 AM
Tom-05-MR
Aug 14, 2008 02:35 PM
jcsbanks
Dec 5, 2007 03:43 PM
kkarim
Nov 26, 2007 06:51 PM
