Wider Tires Affect MPH
Old Dec 4, 2008 | 09:03 AM
blackdemon's Avatar
Don't know if it matters. But on that day that i traped 113 tire pressure was 18psi front 22psi rear
Old Dec 4, 2008 | 09:23 AM
mike1023's Avatar
at your hp in your car you may not see the effect of it as much if you more hp and when drag becomes a problem. 100-110mph is when drag needs to be looked at a lot more.
Old Dec 5, 2008 | 03:02 AM
blackdemon's Avatar
Well we will see. Englishtown re opens in march. all im changing is the tires to oem size. And see if the trap goes up.
Old Dec 5, 2008 | 06:40 AM
mike1023's Avatar
are you tires now taller then the stock ones? if so you deff will get a better et time and mph should go up a little. reason beening is your not even making out the 4th gear. and you can rev it out to 8300 on stock head. {thumbup** best of luck
Old Dec 5, 2008 | 06:49 AM
Audi2ptzero's Avatar
They are actual smaller then the stocks.
255/40/17 = 25.0 in Diameter - 78.6 in Circumference
vs
235/45/17 = 25.3 in Diameter - 79.6 in Circumference
So going back to stock will raise the gearing. The trick is to setup the gearing so you hit the traps right at peak hp.
Old Dec 5, 2008 | 07:32 AM
blackdemon's Avatar
1st through 3rd i was shifting at 7500rpm by the end of the track in 4th gear i was hitting my rev limiter 7850rpm
Old Dec 5, 2008 | 08:39 AM
mike1023's Avatar
rev to 8000 and shift
Old Dec 5, 2008 | 09:32 AM
blackdemon's Avatar
I might just try that
Old Dec 5, 2008 | 01:25 PM
blackdemon's Avatar
vs
that explains why i have to shift faster.
Old Dec 6, 2008 | 02:27 PM
blackdemon's Avatar
Whats the fastest times you guys seen with the power im making?
Old Dec 6, 2008 | 04:10 PM
blackdemon's Avatar
bump
Old Dec 11, 2008 | 10:20 AM
Spoolin18's Avatar
You can try a 245/45R17, these are slightly bigger than the stock 235/45/R17's. This would help raise the gearing!
Old Dec 11, 2008 | 12:16 PM
blackdemon's Avatar
Thank you for the advice
Old Dec 11, 2008 | 12:33 PM
JSC Speed's Avatar
Former Vendor
Originally Posted by CBRD
wider tires have more aerodynamic drag... more frontal area...
cb
This is correct, more surface area will cause drag.
fluxcapacitor
Outlander Sport
Mar 1, 2013 05:27 AM
wazzelby
May 29, 2012 10:09 AM
88888
Jan 29, 2012 01:39 PM
partyboy1122
Sep 3, 2009 11:23 AM
inphluence
Apr 24, 2008 10:16 PM
