launching methods
Old Feb 25, 2009 | 11:44 AM
ch53avitech's Avatar
launching methods
I recently finnished reading a post on Z06 vs. FP Red and I read several suggestions to brake boost. I understand what is meant by that method of launching. My question is. What are the benefits of brake boosting vice 2-step?
note: I understand that brake boosting and 2-step are not the same thing.
Old Feb 25, 2009 | 11:54 AM
evane's Avatar
brake boostin and 2 step are not the same....
my launch goes like so....
Stage the car...
Press the clutch in all the way...
Let the clutch out slowly until the car lurks forward...
Push the clutch back in just enough to stop the car from rolling AKA the sweet spot....
Hit the 2-step mines at 5800 rpm...
Slip the clutch out to engage the clutch/ drivetrain...
As soon as the drivetrain is engaged i let the clutch out fast...
Old Feb 25, 2009 | 12:21 PM
Qustion answered.
Thanks evane.
Close please.
Old Feb 26, 2009 | 10:40 AM
Meeh Lucky IX's Avatar
Brake boosting is a technique used to get the turbo to spool/boost by depressing the brake pedal and appling more throttle at a constant speed it will allow you to get the turbo spooling so your not in lag when you go into WOT. This technique is mostly used in highway runs for example a race from 30mph-140mph or whatever they race from : )
Old Feb 26, 2009 | 02:32 PM
Sideck's Avatar
where is that thread??
Old Feb 28, 2009 | 11:38 PM
uncenteredselF's Avatar
yes please a link to that thread , drag is new to me im more into ridin clay/dirt or rocky roads lottsa corners but i wanna try to c how fast my car is with the new stock spooling 450 it should prode in a few weeks cuz it was gunna try for 500 but i drive it ruff everyday and spoolin instantly with boost good to 8 ill be dying to post my dyno and then time sheet
Wats the best way like i dont know all the terms with launching all others i got down just new area
Old Mar 2, 2009 | 12:03 PM
Tom W's Avatar
I don't own a Evo, i have a WRX. Heres how i launch my car:
1. clutch pedal to floor
2. car is put into first gear
3. lift the clutch pedal to where its just at the point where its going to touch the flywheel and hold it there
4. tap the gas pedal a few times and rev it between 4-5.5k rpm
5. hard to explain this part so..... let off on the clutch, do not slip it or dump it but imagine you just stepped in dog crap, thats how your foot should react BUT do not let the clutch go back on its own weight AND at the same time put the gas pedal to floor (WOT)
Old Mar 2, 2009 | 02:36 PM
Audi2ptzero's Avatar
Want to go WOT before you release the thottle. This way the turbo is spooling as quick as it can and the rpms are rising quickly. Exactly how I do it in all the AWD cars I drag race.
Old Apr 7, 2009 | 01:50 PM
zedevo's Avatar
Nice thread ... Launching is an ART , each set up has his own way to launch...
Old Apr 7, 2009 | 02:26 PM
CNano8's Avatar
Yeah it takes some time and practice but you'll get it. **** the other night with my 2step at 5500 I left 15 foot strips on the ground with snow tires (i.e. poor man drag radials)!
Old Apr 8, 2009 | 04:03 AM
zedevo's Avatar
lol ...
Old Apr 8, 2009 | 04:06 AM
idriveanevo's Avatar
launching also depends greatly on the surface or the track you on
Old Apr 8, 2009 | 04:20 AM
zedevo's Avatar
^^ 100%, Cause on normal Street Asphalt i lauch @ 5.500RPM ... Next Sturday i have a very HOT DRAG Race with Extremely Light Wight Golf I 4wd Turbo ... the race gonna be on Very Large in a Huge Close Airport ... The Asphalt is VERY HARD to launch , cause the grip is Awesome but I'm AFFRAID To Say good bye to my tranny and Transfer Case :S ...
Ill Try it ... This race is VERY IMPORTANT to me, Ill Part my car to have it on 1200kg Minimum...
Im running curently on Yokohama Advan 255/35/18... on ADVAN RS Wheels 18 x 9'' ...
How much should i have PSI in my tires ... Or u prefare 17'' ???
In lebanon we dnt have a Drag Strip :s i have my GTech SS Ill fix it on my car
Any Advice Please ! ...
joe
Old Apr 19, 2009 | 08:26 PM
ODUB's Avatar
Launching is simple.
Step 1: Stop
Step 2: Push in the clutch
Step 3: Put the car in first gear
Step 4: Let the clutch out to find where it engages and hold it just before that (it'll make it easier to slip/dump)
Step 5: Floor the gas, and hold it to the floor. You will start bouncing off the 2-step at 5000rpm and build around 10psi.
Step 6: DO NOT let off the gas pedal at ALL, slip out the clutch until you feel it grab, then let go.
Step 7: DO NOT let off of the gas pedal until you shift to 2nd gear. The gas pedal should be held to the floor from the beginning until you shift to 2nd.
Step 8: Continue shifting gears accordingly.
that's how i've always done it, and it was good enough to get me and my basically stock IX MR to 12.82 @ 107.41 with only a cat back, no tune, no other power adders, a boost leak, and a possibly slipping stock clutch.
Old Apr 19, 2009 | 08:40 PM
jaycheetwood's Avatar
Wow you all should write up a how to launch. haha.
I am taking my to the track soon and you guys are really helping my out.
