launching methods
Old Apr 29, 2009 | 12:00 PM
FastAzzEvo's Avatar
Originally Posted by ODUB
Launching is simple.
Step 1: Stop
Step 2: Push in the clutch
Step 3: Put the car in first gear
Step 4: Let the clutch out to find where it engages and hold it just before that (it'll make it easier to slip/dump)
Step 5: Floor the gas, and hold it to the floor. You will start bouncing off the 2-step at 5000rpm and build around 10psi.
Step 6: DO NOT let off the gas pedal at ALL, slip out the clutch until you feel it grab, then let go.
Step 7: DO NOT let off of the gas pedal until you shift to 2nd gear. The gas pedal should be held to the floor from the beginning until you shift to 2nd.
Step 8: Continue shifting gears accordingly.
that's how i've always done it, and it was good enough to get me and my basically stock IX MR to 12.82 @ 107.41 with only a cat back, no tune, no other power adders, a boost leak, and a possibly slipping stock clutch.
I dont think two step works unless clutch is all the way to floor.... if your engagement is right new floor then maybe... which it shouldn't be imo
CFMP RAblue
Mitsubishi TC-SST Discussion
Sep 20, 2014 03:02 PM
ra_guy
Jan 30, 2012 08:23 PM
bacquerel
May 18, 2011 06:03 AM
AM-EVO
12
Jul 16, 2009 04:13 AM
salukidude
Evo X How Tos / Installations
15
Aug 14, 2008 04:09 AM
