10.5@131mph FP Red
Old Mar 1, 2009 | 05:00 AM
RyuEvoIX's Avatar
10.5@131mph FP Red
Yesterday was one heck of a day. Unfortunately I did not hit my 10.3-10.4 goal. The car is most definitely capable, the driver and clutch were the weak links yesterday along with a 15mph headwind . My best 60ft of the day was a 1.61 but regrettably I was locked out of 4th on that run along with at least half of my runs yesterday. Most definitely time for a new Exedy Twin clutch kit. All and all not too bad for a brand new never dialed in setup and an uncooperative clutch. I will be going back in April to another private track event with a few changes to the setup that should allow for more power and hopefully better 60ft's.
VIDEO-http://www.youtube.com/watch?v=F8BKvLghF1E
MOD LISThttps://www.evolutionm.net/forums/ev...wtq-33psi.html
Old Mar 1, 2009 | 05:03 AM
Malik_EvoIX's Avatar
nice on stock turbo i am assuming you have upgraded t-case,diff ?!
Old Mar 1, 2009 | 05:05 AM
RyuEvoIX's Avatar
This is on the FP Red and I am on the factory T-case launching at 7100rpms.
Old Mar 1, 2009 | 05:07 AM
amui07's Avatar
Definitely seems capable, good luck on your next attempt.
ahhh sry just woke up in early morning. nice to see a stock t-case in a 10 sec car. how often you change t-case fluids?
Cyloc's Avatar
good job. It is still a good time for the first time out on a new setup. After your new changes are done, you will nail it with now problems.
Old Mar 1, 2009 | 05:13 AM
RyuEvoIX's Avatar
Thanks. It's simply going to take more seat time. Launching with the Red is completely different then launching the car with the stock turbo.
Normal 15k maintenance. The faster the car gets the less often I seem to beat on it.
Old Mar 1, 2009 | 05:16 AM
RyuEvoIX's Avatar
Thanks Anthony, but you know me. Once I put my mind to something I'm not satisfied until I have accomplished it.
Old Mar 1, 2009 | 06:18 AM
markymark1082's Avatar
Good fun and good times yesterday. Hopefully I'll make it out again to the next meet. Now learn how to launch that car.
Old Mar 1, 2009 | 06:24 AM
SparkTech's Avatar
Nice Job...low 10's is Most definitely in your future
Old Mar 1, 2009 | 06:28 AM
silver9mr's Avatar
great times and when you said the launching is differnt then on a stock turbo how much so?, im so excited for my red to be here soon
Old Mar 1, 2009 | 06:29 AM
RyuEvoIX's Avatar
Thanks SparkTech. That's the plan. Just need a little more time to dial in the 60ft
Old Mar 1, 2009 | 06:31 AM
Ranvir's Avatar
Good job man. Low 10s just a clutch change away.
Is the car full weight? And what fuel was in it?
Old Mar 1, 2009 | 06:33 AM
RyuEvoIX's Avatar
With the stock turbo I was able to rev up to the 2step and let the clutch out with over 10psi. With the Red it takes longer to build boost so the launch technique is completely different launching at the desired boost level. If I don't stay on the 2step long enough I bog and if I stay on it too long I spin. It's going to have to take some practice to get the timing just right again.
Old Mar 1, 2009 | 06:34 AM
RyuEvoIX's Avatar
Thanks, that is most certainly the plan.
Race weight is 3150lbs, 93oct+100%methanol injection.
