Have a question about shifting?
Old Mar 12, 2009 | 10:53 PM
SpinninAll4s's Avatar
Originally Posted by EvoIX Beauty
wot shifting is the way to go! still going strong on my stock tranny - u should be fine altho i understand ur concern.
Hey man you should hit up union grove this year! I will be going for every RSD event. It gets pretty crowded.
Old Mar 13, 2009 | 08:07 AM
EvoIX Beauty's Avatar
i've been going to GLD for yrs and have been to every RSD. tho lately i've been going to byron where there isn't as much drama. we'll see how the beginning of the season goes since i'm sure i'll start out at GLD.
Old Mar 13, 2009 | 08:49 AM
RyuEvoIX's Avatar
Here's an example of lift shifting vs NLTS on my car. The example is 4th gear ONLY in the two video's though. In the first video I NLTS into 4th gear and in the second video i LIFT SHIFT into 4th gear mainly because I was getting lockout by trying to NLTS due to a worn clutch.
NLTS 4th gear: http://videos.streetfire.net/video/E...OCK_372930.htm
LIFT SHIFT 4th gear: http://www.youtube.com/watch?v=F8BKvLghF1E
Old Mar 14, 2009 | 12:09 PM
Lvis's Avatar
Originally Posted by aka.ralliart15
No Lift To Shift
Wide Open Throttle
It means that you shift without lifting your foot of the gas, making quicker gear changes into better rpms. But if you don't have the patch in your ecu that drops the revs a little, you're gonna have to shift quickly or you'll hit the rev limiter.
what program has that patch? ecu reflash?
Old Mar 14, 2009 | 07:35 PM
C130flyer's Avatar
If you shift slow enough that you have to use the patch to not hit the limiter, you probly aren't really gaining anything and should just shift normally.
Old Mar 14, 2009 | 08:00 PM
RyuEvoIX's Avatar
You have completely missed the point of the NLTS patch. The benefits are as follows:
1. Drops revs to help rev match into the next gear for a smoother shift and less drivetrain shock.
2. Allows you to hold more boost in between gears then normal power shifting.
Old Mar 15, 2009 | 06:08 PM
C6C6CH3vo's Avatar
Just watch the vids of mostwanted
Old Mar 17, 2009 | 09:54 PM
awdwannabe's Avatar
I've only been to the track once being basically all stock, with times in my sig. But I've never NLS, what I basically do is just lift my foot off the floor about what I guesstimate is around an inch, shift into the next gear, then put my foot on the floor again. It's essentially WOT shifting, but not.
Old Mar 18, 2009 | 06:51 PM
aka.ralliart15's Avatar
Here you go
https://www.evolutionm.net/forums/ec...d-v5-10-a.html
Old Apr 6, 2009 | 04:18 PM
zedevo's Avatar
When u LIFT SHIFT : 10.5sec
on NLTS : 10.9
Usually it has to be vice versa No ???
Old Apr 6, 2009 | 08:21 PM
rolly1818's Avatar
Registered User
i always though NLTS saves the Gearbox and T-Case???
Old Apr 7, 2009 | 05:14 AM
juanmedina's Avatar
on NLTS : 10.9
more info
Old Apr 7, 2009 | 07:23 AM
You guys definitely need to learn how to read!!
10.9 - stock turbo
10.5 FP RED
Old Apr 7, 2009 | 09:38 AM
C130flyer's Avatar
If you aren't shocking the driveline then you aren't gaining everything that can be had from NLTS.
If you guys are worried about breaking your cars then STOP racing.
Old Apr 7, 2009 | 10:12 AM
juanmedina's Avatar
so you guys NLTS every gear?
