1/8 mile time fp red evo IX
Old Jun 8, 2009 | 10:29 AM
griffeyr's Avatar
went to the local 1/8 mile dragstrip on saturday june 6th....first time running the 1/8 mile, and first time at the track period with this setup
Evo IX (mods in sig)
93 octane
Boost 23.6 psi
2 step set at factory level
Full weight (minus the spare and car had about 1/2 tank of gas)
stock evo x yokahamas
60 ft. - 1.81
330 ft.- 5.16
1/8- 7.93
mph- 87.8
Old Jun 9, 2009 | 01:32 PM
dsmfan95's Avatar
Could you post a full mod list, your signature doesn't really show much.
It seems like you're a bit down on power, I would expect like low 90's trap for an average Red setup on pump gas.
Old Jun 10, 2009 | 03:10 AM
griffeyr's Avatar
boost was just 23.6 psi....when i was being tuned my fmic was heat soaked thats why the low boost....also numbers were on cbrd's mustang dyno
injen intake and uicp, turbo xs fmic, evo power mods licp and 02 dump, gsc s1's, blitz boost controller, 880's, fp red turbo, walbro pump, dc sports 2-1 catless dp, greddy tic cb, ported stock em
Old Jun 10, 2009 | 03:13 AM
SOEuro's Avatar
agreed,seems like stock turbo times
the RED needs MORE BOOST!
Old Jun 10, 2009 | 06:29 AM
griffeyr's Avatar
im not the worlds greatest driver either
Old Jun 10, 2009 | 06:31 AM
Import Junky's Avatar
damn griffey you aren't having much luck so far with this Red. I'm sure with some better driving you'll bring the time down.
Old Jun 10, 2009 | 07:09 AM
aka.ralliart15's Avatar
its all in the practice, i remember the first time i raced mine i was neck to neck with modded GTI's, running like 9.2-9.4 in the 1/8th lol
Old Jun 10, 2009 | 07:14 AM
griffeyr's Avatar
any tips on how to lower my time??? i dunno what im doing wrong
Old Jun 10, 2009 | 07:21 AM
Couple questions....What clutch do you have? Any motor mount? Shifter Bushings? Shift Knob? Engine Damper?
Old Jun 10, 2009 | 07:35 AM
griffeyr's Avatar
act street clutch....no motor mount, shifter bushing or engine damper...do have the silver shift knob from mitsu accessories
Old Jun 10, 2009 | 07:42 AM
K well since you have the ACT im sure you are having trouble getting into second gear after the 2-step launch and sometimes into third cause I had the same problem.
Since then i got the shifter bushings and the greddy counter weight shift-knob which allowed me to bang thru the gears a bit easier. I would do those two for now which are relatively not that expensive and see if that makes it any better. then you can get the other two things if you'd like to hold the motor in place.
Old Jun 10, 2009 | 08:51 AM
C6C6CH3vo's Avatar
For the 1/8, the ET is all in the 60' and the 2 and 3 catch. HP helps but there's only 1/8 mile to launch and shift 2 or 3 times.
In the 1/4 you can make up with HP in 4th. I never ran the 1/4 and haven't been to the 1/8 in several years. But I know the 1/8 is a driver's race (+luck)
Old Jun 19, 2009 | 04:10 PM
neonhorse's Avatar
Admittedly we are a little short on the 1/8 track here, and they dont give us 60' times, so , here is my .o2. I have to slip the clutch quite a bit to get a good launch. If you are missing gears, it makes it really hard to get a sub 8 in the 1/8. I can drop from a 7.6-7.7 to an 8.1 with just a hard time getting it in gear. Thanks for the info about the shifter busshings and such, maybe that will fix my problem with shifting.
cat back exhaust
K&n intake
lightweight flywheel
evo ix
Old Jun 19, 2009 | 04:24 PM
griffeyr's Avatar
cat back exhaust
K&n intake
evo ix
no missing hears....once i get my 60 ft. time down, i'll be set
Old Jun 19, 2009 | 04:35 PM
toverton30's Avatar
i want a fp red..... i run like a 8.?
