"Street Monster" With only 23PSI of boost going 11.2!
Well went to the track and was messing around and i was not going for all out fast but my boost was 22-23psi. And it was a very hot day 80f+. Just going to enjoy my the crowed and the event. and some how my car does not like going slow i guess and pulled off a 11.2 at 123.
I will post the time slip when i get home later.
I know everyone will ask whats on the car lalal
Very easy setup.
-FP red turbo
-Mike1023 spec motor
-BR fmic
-BR pipe
-BR tbe
-aem (changing one map then 4 is a lot easier in my book!)
Stock head, stock suspension, stock brake, full interior, mike1023 spec radio.
I also know people going to say ya so you run low boost and a butt load of timing!
well i running around 7-8degrees of timing. and i added some fuel up top. tried to make it slower but the thing has a mind of its own and wants to go fast no holding this bad boy back!
keep posted for new times.
Very easy setup.
-FP red turbo
-BR fmic
-BR pipe
-BR tbe
Not alot of timing, not a lot of boost and i can throw around alot of cars all day.
Curb weight? i dont know how much a curb weights sorry.
And i was seeing 22psi in 1st and 2nd and then started seeing 23 in 3rd and in 4th just almost 24 but was holding 23 all to red line.
thanks man
radio is ~3lb for the totaly system. and yes i do get fm and am channels and its loud! works great. if you do a little search on my name you will see i made a thread about it in the audio.
I have changed the ipod to a small small ipod/fm radio unit. which is no like a 1"x.5" big and weight in at i dont know does not read on my scale LOL.
Cams are BR Power
Compression i have no clue. I know its not those wild 10:1 its a street motor. very nice!
What is your best time btw?
best time is 10.9 last year. was first week i got the car back and went 10.9.
and ya i dont know the compression i drink to much
thanks man
But for you to come on the board and say, "look at me!", "i'm special!", "i run no timing and no boost!"... it sounds dumb. Your car is either tuned well or it isn't. That is the only answer. One guy can run 20 degrees at 7k and another guy 3 degrees. It just doesn't matter or make any difference. You're either tuned properly or not.
Are you telling us you are not tuned properly?
and some no name 93oct, Maybe that is the secret, LOL. I cant believe it went that fast on NO BOOST! SICK!!!
