slicks
Old May 6, 2010 | 08:19 AM
raiceboi697's Avatar
slicks
is there a difference between a DOT slick with a groove cut in it, like a hoosier QTP versus a all out not DOT slick, like the micky thompsons?
Old May 6, 2010 | 01:24 PM
sho669's Avatar
sidewalls are a little softer in a all out race setup i've been told (both being wrinklewalls). compounds used are usually pretty close. on a couple camaros i've built i had issues getting them to hook on dot M/T's but the full slick M/T's same size and press hooked fine.
Old May 7, 2010 | 07:51 AM
so do you think its worth the extra bucks for a legit non DOT slick? could it mean the difference of a tenth or two?
Old May 7, 2010 | 07:57 AM
sho669's Avatar
From my own personal experience I would say yes. I've seen it happen more than once, bolt em on and go hit some 9's
Old May 7, 2010 | 01:05 PM
neonglh's Avatar
Of course. The QTPs are still a street slick. The ET Drag is a full out drag slick!
Old May 7, 2010 | 01:16 PM
wizzo 8's Avatar
If your getting slicks for the track why not go all out and get some true slicks. No dot approved
Old May 12, 2010 | 12:32 PM
cause im lazy and will most likely not take them off and dont wanna burn through 800 in tires in 6 months.. lol
Old May 12, 2010 | 12:40 PM
and i understand there is a difference mark but im curious as to if the juice is worth the squeeze u know, its a lot of money to blow...
Old May 12, 2010 | 01:24 PM
Svendiesel's Avatar
Why not try out the Hoosier 245/45-17 slicks from 9sec9's site? Im thinking about picking them up because theyll fit on the stock size wheel.
I dunno if that appeals to you but it does to me because I dont want to have to do a small brake kit and dont want to get a whole new set of wheels to fit the QTP's on.
Old May 13, 2010 | 07:08 AM
I already have the small brakes from ams to run a smaller rim and have less rotational mass. The weight difference is insane between the stock rims with a motorcycle slick and a 15 inch rim with a slick. And for what I'm trying to do with my evo, every lb counts
Old May 14, 2010 | 06:32 AM
FL_SilverEvo8's Avatar
Can you run this small break set up for D/D cars? I heard it wasn't good to do Then I hear people saying you can. Confusing.....
Old May 14, 2010 | 10:28 AM
Draven83's Avatar
I dd that kit for about a year. so i say you can and james has been for a few months now also.
James just buy the same fricking tires i have and get it over with. then get back on that track.
Old May 14, 2010 | 04:23 PM
hey now its a lot of cash, if a non DOT slick is worth a tenth more then its worth the extra cash IMO and yes you can use the small brakes for DD. AMS says you shouldnt use them for auto x type events though cause they cant handle the extra heat cause of there size
Old May 14, 2010 | 07:38 PM
EmeryatSTM's Avatar
A real slick will destroy a DOT tire all day long...
Old May 14, 2010 | 07:48 PM
lillev23's Avatar
You can actually get the M/T slicks from Summit for cheaper than the Hoosier QTP. No brainer for me, unless you are trying to be competitve (which makes no sense if you are on stock block).
