shifting
Old Dec 20, 2003 | 05:17 PM
2003EVO's Avatar
shifting
I have a stock evo with just the boost restrictor taken out. I will hit 22 lbs and bleed down to 16 to 17. I'm pretty sure since there is a big sixteen in this car you can take it up high in the rpm's and not lose much boost. what are the rpm's that some of you all shift at to get the best run.
Old Dec 20, 2003 | 05:28 PM
fastmarsh's Avatar
Check out some other forums on the Resistrictor pill and it's effect on the car. Run a search and you should find them
Good Luck
Old Dec 20, 2003 | 05:33 PM
2003EVO's Avatar
i know what the restrictor pill did by taking it out. stock, it hits 19 lbs and bleeds to thirteen. I basically just want to know what rpm most people shift at when going down the track.
when i get on it on the street, i'll take it all the way to 7 grand. Is that too much, or not enough?
Old Dec 23, 2003 | 11:20 PM
rallyred's Avatar
my best results at the strip where shifting at 7200 to 7300
Old Dec 24, 2003 | 10:28 AM
2003EVO's Avatar
i raced it on sunday and ran a best of 13.299 @ 103 with a 1.87 '60 shifting at 6000 to 6500
when i would let it go above 7300 i could only get a 13.5 out of it.
that clutch is tricky, out of about 15 times of racing it, i bogged the launch about 9 times
Old Jan 19, 2004 | 02:41 PM
High Voltage's Avatar
What do the Evos red line at?
Old Jan 19, 2004 | 03:10 PM
2003EVO's Avatar
7000 to 9000 are in the reds
GreeceS13
AEM EMS
Nov 22, 2015 10:46 AM
krazyb
Evo X How Tos / Installations
39
Mar 28, 2014 05:51 PM
evo_skillz
Dec 30, 2006 06:09 AM
initialD
Driving Techniques
21
Feb 7, 2004 11:39 PM
Scot
Apr 7, 2003 12:55 PM
