Has anyone tryed these DR's?
Old Jun 1, 2011 | 10:46 PM
FL_SilverEvo8's Avatar
I was wondering if anyone have tried the Toyo Proxes TQ? If anyone has a 16" rim and wants to ride on the street they might be good. They make them in a 255/50-16 it would make them 26" tire.
http://toyotires.com/tire/pattern/proxes-tq
Old Jun 1, 2011 | 11:26 PM
GotWheelHop's Avatar
Why on earth would you run those? If you are going to go to a 16" wheel setup, why not use QTP's or a slick? I understand you said for street driving, but you can run 17 inch r-comp's with similar results on the street. You don't want a 16 inch soft sidewall tire when you are going around corners.
Old Jun 1, 2011 | 11:34 PM
EvoFredo's Avatar
I daily drive my car way too much for any soft compound tire. a sticky tire like that would have to have its own set of track wheels IMO.
Old Jun 1, 2011 | 11:37 PM
caLi4G63's Avatar
Interesting; never herd of anyone running those. I wonder how soft the sidewalls are. As stated by GotWheelHop, on a 16" wheel, you're better off with Hoosier QTPs unless you plan on running around town with them, then, that wouldn't be a wise choice.
Old Jun 4, 2011 | 05:56 AM
Canexican's Avatar
The only way I can see running those is if you have a 17x9 wheel and didn't want to run separate wheels and tires for the drag strip. Those sidewalls would probably be pretty damn soft.
I currently have 255/35/18 Toyo R1R's that i've been taking down the strip. Best 60ft so far was a 1.66 with them. They've got a 140twr and a sidewall on the softer side, so they tend to hook better than most.
Old Jun 4, 2011 | 10:25 AM
I was just throwing it out their. I am going to run Hoosier QTP's for my track set up.
Old Jun 5, 2011 | 06:00 PM
EvoDan2004's Avatar
there very heavy tires too. i would not use them. nearly 2 to 3 lbs heavier per tire then most DR tires. and 7 lbs heavier PER corner then the Hoosier 245/45/17 DR.
Old Jun 6, 2011 | 07:31 AM
Thanks for the info. No wonder no one uses them then. Are the 16 that heavy too?
Grippy Tire
Evo 'For Sale' Wheels / Tires
64
Aug 17, 2010 10:36 PM
Kidloco51
42
Feb 3, 2008 01:06 AM
ModenaTwinTurbo
For Sale - Wheels / Tires
Mar 27, 2007 09:57 PM
LoCo4
Jul 21, 2006 07:18 PM
ROCK
Lancer Vendor Classifieds
34
Nov 6, 2004 09:34 AM
