Back from the track with the daily driver 9.88@144mph
Old Sep 17, 2011 | 08:14 PM
  #91
Wickedwhite8's Avatar
Holy consistent,lol. That's moving dude Congrats
Old Sep 18, 2011 | 09:08 PM
  #92
evodude32's Avatar
Thanks man
Old Sep 18, 2011 | 09:23 PM
  #93
fre's Avatar
fre
Well glad to hear the car held up and did as well as before. Better than I can say about my turd, not surprised though.
Old Sep 19, 2011 | 09:15 AM
  #94
PATRICK B.'s Avatar
Good to see it back on track Jake what kinda boost are you running through the 3586?
I know it's probably been asked before but do you think you are needing more rpm in each gear?
Also how much work was done to the head?
Old Sep 19, 2011 | 11:41 AM
  #95
evodude32's Avatar
Running 37lbs peak tapering to 36-35.
I do need more RPM through 1st gear and 4th. More in 1st so I can hold it out longer for a better 1-2shift and 4th since I'm crossing through right at 8800rpm through the traps. The car does have an awesome powerband though, 5500rpm through 8700rpm, so it's fairly wide and very responsive between shifts.
I'm more then likely going to step back down to a 2.0l next season so I can go faster. The stroker is awesome, but I'm just out of RPM, unless I go to a 4:11 final drive.
The head has mild port work done and supertech 1mm oversized valves with supertech dual springs, bronze guides and the kelford 272 cams.
Old Sep 19, 2011 | 03:30 PM
  #96
evodude32's Avatar
I was sitting here looking at my timeslips from this season and WOW, this thing is extremely consistent lol.
9.97
9.89
9.88
9.89
9.91
9.90
9.92
9.93
9.94
All of these runs ranged from 90+ degree weather to as cool as 60 degree weather. It runs the same numbers regardless of temp. I've had some consistent cars in my life but damn, this is like a automatic trans bracket car haha
Old Sep 19, 2011 | 05:05 PM
  #97
PATRICK B.'s Avatar
9.97
9.89
9.88
9.89
9.91
9.90
9.92
9.93
9.94
You and me both Jake!
I'd have more by now but the car is down now trying to dip deeper into the 9's.......hope to keep the consistancy but still run sub 9.50
9.999
9.932
9.888
9.873
Old Sep 19, 2011 | 07:51 PM
  #98
evolution666's Avatar
Sweet bro.
Old Sep 19, 2011 | 08:43 PM
  #99
Paul Walkin's Avatar
I'm guessing it'd be faster 2.0/stock fd vs 2.3/4.11?
Old Sep 21, 2011 | 04:21 PM
  #100
evodude32's Avatar
I think it would be faster on a 2.0l since it will settle the tires down a ton on the launch (less tq) It's pretty tricky launching this thing with the amount of tq it has, so cutting good 60ft's is tough needless to say
Not to mention I will be able to rev the 2.0l higher during shifts. If I do go back to a 2.0l it will still remain the stock final drive. If I stick with the stroker then i will more then likely have to goto a 4:11 final drive if I wanna go any faster then I am now.
My goal by the end of the season is to hit 9.6x and 147-150mph. I don't think I will be able to hit 150mph with my current setup though, 147mph isn't too far out of reach. I'm going to adjust the rear suspension again and see if I can get my 60ft's down in the 1.4x range.
Next outing will be on Oct. 9th, maybe sooner, we shall see.
Old Sep 26, 2011 | 09:49 PM
  #101
Spoolin20v's Avatar
nice pass. thats quite the ET/Trap for a daily driver
Old Oct 25, 2011 | 12:42 PM
  #102
teribble's Avatar
Great setup.... Wheres the update?
Old Oct 25, 2011 | 04:05 PM
  #103
evodude32's Avatar
Sorry, no updates to give. We only have one more event at our local track and then the season is over till spring. Not sure if I will be able to make it.
Old Nov 29, 2011 | 02:19 PM
  #104
PATRICK B.'s Avatar
Hey Jake just checking back with ya i know there is no more racing for ya this year but any thoughts on what you will be doing with the Evo for next year or will you just keep it as is and have fun with it?
HAPPY HOLIDAYS my brotha!
Old Nov 29, 2011 | 02:49 PM
  #105
fre's Avatar
fre
Knowing Jake, he will keep trying to make it faster. I don't think he will go as far as to put crap doors/lexan windows on it though. Probably just try to push more power out of it and shoot for mid 9s.
My goal is to see if I can even break 11.5 again without breaking my car.
